[工业机器人] FANUC ROBOGUIDE V9.1098 (Rev.F)
zhangbing 发表于 2019-4-22 21:22:11 | 显示全部楼层 |阅读模式
下载链接:
https://www.eleok.com/thread-121687-1-1.html
1. What's new:
        Support for new robot models:
                CR-15iA
                ARC Mate 100iD/10L
        Support for V9.10P/10, V8.30P/40, V8.10P/30 virtual robots.
        Support for CAD converter option. CATIA, Creo, Inventor, NX, PRO/E, Solid Edge, SolidWorks, STEP, Parasolid, JT, IGES (surface, solid) are supported.
        Support for near miss check.
        Improved user interface:
                Support for preset extended axis settings in virtual robot edit wizard.
        FC Deburring Package:
                Support for setting of motion instructions and wait instructions for base position programs and find edge programs.
        Machine Tool support:
                Support to start and stop NC program on NCGUide from ROBOGUIDE.
                Support to generate a workcell of QSSR vision detection.
        Modeling function:
                Support to generate the roller conveyor and curved conveyor.
                Support to generate clamp type hand
                Support to generate low-profile type air gripper on chuck library.
        Improved spray simulation:
                Support to attach a nozzle to link on robot tool.
                Support to paint a workpiece attached to link driven by I/O signal.
        Improved spot welding function:
                Support to set interlock among multi-arm robots.
2. System Requirements
                                        Recommended Minimum
        Operating System        Windows 10 (32-bit and 64-bit)
                                Windows 7 (32-bit and 64-bit)
        System Memory                1 GB; 4 GB recommended.
        Video Card:
        OS Requirements                Sign in Administrator user to install product and
                                Internet Explorer 11
                                Normal font size (96 DPI).
                                Windows RT is not supported.
GMT+8, 2025-4-2 06:54
