[工业机器人] FANUC ROBOGUIDE V9.10121 (Rev.G)
zhangbing 发表于 2019-4-22 18:35:34 | 显示全部楼层 |阅读模式
下载链接:
https://www.eleok.com/thread-121688-1-1.html
1. What's new:
        * Support for V9.10P/15, V8.30P/44, V7.70P/53 virtual robots.
        * Support M-20iB/35S adding estimation function.
        * Measurement tool: Support to display the surface-angle between FROM and TO surfaces.
        * Improved user interface:
                - Support multiple selection on part tab and simulation tab.
                - Support multi-line selection on simulation program editor.
                - Support to display the object name while hovering mouse cursor.
                - Support for prompt message when deleting an item from cell browser.
                - Support new dockable Image Library to quickly add objects to the workcell.
                - Support for Searching/Replacing/Jump-to functions in TP programming.
                - Support to display point position data (XyzWpr) at TP point Node Map.
        * Support 'No UOP Control' mode in simulation start selection.
        * Support to display and modify actual value of I/O state on I/O panel.
        * Support to transfer signed/unsigned values between external devices at external device connection.
        * Support Workcell wizard for building NCGuide Workcell in Machine tool.
        * Modeling function
                - Support pallet model generation.
                - Support measure function.
                - Unify chuck library and clamp library.
                - Support taper type jaw to hand generation.
        * Support Target model collision check function at DCS property page.
        * Support ROBOGUIDE 3D Player - provides 3D playback of robot workcell.
                - Create: RG 3D player installed with ROBOGUIDE. Use ROBOGUIDE to create RG 3D Video.
                - Playback: full ROBOGUIDE not required to run 3D video.
        * Automatic Components provide enhanced workcell devices for more realistic simulation of workcell components.
                - Rev G supports the ROBOGUIDE Automatic Components Infeed Conveyor with flowing boxes and interface signals that model real world conveyors.
        * PaintPRO Analytics:
                - Profiler Summary: lists all devices and their profiler summary data, including  init. data, cycle times, conveyor wait times, gun-on times and total time.
                - Wait / Release Macro Table: displays all Wait and Release macro instructions from all devices in one table.
2. System Requirements
                                        Recommended Minimum
        Operating System        Windows 10 (32-bit and 64-bit)
                                Windows 7 (32-bit and 64-bit)
        System Memory                1 GB; 4 GB recommended.
        Video Card:
        OS Requirements                Sign in Administrator user to install product and
                                Internet Explorer 11
                                Normal font size (96 DPI).
                                Windows RT is not supported.
zhao123lang 发表于 2020-1-6 09:44:38 | 显示全部楼层
不错:lol:lol:lol:lol:lol
GMT+8, 2025-4-20 13:34
