[PLC编程] SIMATIC CFC V8.0 SP2 Upd2
山海致远 发表于 2019-3-7 22:54:53 | 显示全部楼层 |阅读模式
SIMATIC CFC介绍和安装文件下载网址
可提供此软件远程安装服务,详情查看以下网址内容:
SIMATIC Update 2 for CFC V8.0 including Service Pack 2
Please read the notes carefully; they contain important information on installing and using CFC.
You can find important information on Update 2 for CFC V8.0 including Service Pack 2 in section Notes on Usage / Chapter: 4 Notes on the Update.
Contents
4        Installation
4.1        Installing CFC
4.2        CFC License Key
4.3        Uninstalling CFC
1.1        What’s New?
2.3        CFC for S7
2.4         SFC Instances in the CFC
2.5        Inheritance of the name of a control module type by its blocks
The CFC can be run on the following operating systems:
    • MS Windows XP Professional SP3
    • MS Windows Server 2003 SP2 Standard
    • MS Windows Server 2003 R2 SP2
    • MS Windows 7 Ultimate SP1 32 Bit
    • MS Windows 7 Ultimate SP1 64 Bit
    • MS Windows Server 2008 SP2 32 Bit
    • MS Windows Server 2008 R2 SP1 64 Bit
    • MS Windows 7 Professional SP1 32 Bit
    • MS Windows 7 Professional SP1 64 Bit
    • MS Windows Vista 32 Bit SP2 Ultimate
    • MS Windows Vista 32 Bit SP2 Business
Note: MS Windows XP Home and MS Windows 2000 operating systems are not supported.
        Order number:  6ES7658-1EX08-2YA5
        This product package includes:
    • 1 CD TIA Engineering Toolset V8.0 SP2
    • 1 license key memory stick
    • 1 certificate of license
Contents of the TIA Engineering Toolset CD including CFC
    • CFC V8.0 SP2
    • Minimum 600 MHz processor
CFC is a 32-bit application which requires one of the operating systems listed above.
    • Basic software STEP 7 V5.4 SP5 or higher
    • If using CFC for M7:
Note:
The product SCL Compiler is no longer necessary as of CFC V6.1 including SP1.
The CFC setup itself installs the required SCL compiler functionality with the suitable version (it does not need an SCL license key).
If you installed an SCL compiler with version V5.1.x on the PC, the SCL compiler
must be reinstalled after you have removed the CFC. Otherwise the SCL sources
will no longer be displayed in the SIMATIC Manager.
            You need a PDF Reader compatible with PDF 1.x to read the supplied PDF files.
CFC V8.0.2 requires approximately 90 MB of space on your hard disk.
4        Installation
4.1        Installing CFC
When you install CFC V8.0.2, you can overwrite an existing installation of CFC.
4.2        CFC License Key
Before you can start working with CFC, you must transfer the license key from the license key memory stick to the computer.
If the license key cannot be installed during setup, continue the Setup program without installing the license key. Perform a restart and install the license key via the Start menu entry Simatic > License Management > Automation License Manager.
        Important Note:
        Use the Microsoft Windows application "Add/Remove Programs" (for example, in Windows XP in the taskbar via the Start menu entry Settings > Control Panel > Add/Remove Programs) to remove your software package (for example, "SIMATIC CFC V8.0 SP2"). This is the only way to uninstall software in Microsoft Windows.
Note:
Since 10/01/2003, the SIMATIC M7 automation computer and all the associated components have been discontinued. Although the M7 is still available as a PLC in the engineering system, it has been removed from the documentation and support is no longer provided. You can find additional information under http://support.automation.siemens.com/WW/view/en/14044569.
Security information:
Siemens offers IT security mechanisms for its automation and drive product portfolio in order to support the safe operation of the plant/machine. Our products are also continuously developed further with regard to IT security. We therefore recommend that you keep yourself informed about updates and upgrades for our products and always use the latest version of each product. You can find information on this at: http://support.automation.siemens.com. You can register for a product-specific newsletter here.
For the safe operation of a plant/machine, however, it is also necessary to integrate the automation components into an overall IT security concept for the entire plant/machine, which corresponds to the state-of-the-art IT technology. You can find information on this at:
http://www.siemens.com/industrialsecurity. Products used from other manufacturers should also be taken into account here.
1.1        What’s New ?
Version V8.0.2 contains the following enhancements or changes compared to the previous version V8.0.1:
    • Synchronization of control module types and control modules is supported.
Data created with older CFC versions can still be used as follows in CFC V8.0.2:
    • The CFC V3.x to CFC V8.0 data can be read and displayed with CFC V8.0.2.
Data created with CFC V1.0 or CFC V1.1 can still be used as follows in CFC V8.0.2:
    • The CFC V1.x data can be read and displayed with CFC V8.0.2. Direct editing of CFC V1.x data is not possible here. If you want to edit V1.x data, proceed as follows:
    • Open the project in the SIMATIC Manager and save it under a different name using the menu command File > Save As... and the option "Rearrange before saving (slow)" and select the file type "Project" in the dialog box which appears. The data is then automatically converted to V8 format.
    • You cannot "reconvert" V8 data back to previous versions.
    • After upgrading from older CFC versions, a series of function blocks are replaced in the program by new versions. The old blocks remain in the block container but can be removed with the menu command Options > Block Types > Clean Up.
CFC V8.0.2 still takes upper and lower case symbols into account for blocks in charts; in other words, you can create blocks with the same name, which differ only in the case used. However, we recommend that you use different names to avoid problems in the future.
Message "Key already exists" when migrating older projects to CFC version V8.0.2
Differences in CPU protection
    • In the CFC test mode, write access is also permitted with the key switch set to RUN.
Note of AS-wide interconnections
        With version 7.1.1 we have made changes in the code of the IK_SEND system block. If you upgrade your project directly from version V7.1: You can accept this later version of the IK_SEND in your program by proceeding as follows:
o        Open the CFC library in SIMATIC Manager and select the FC155 (IK_SEND) in the "IK" block folder of the S7 program.
o        Execute the function "Options > Charts > Update block types", while you select all projects that use AS-wide interconnections in the following dialog.
Note of textual interconnections in F programs
When the "Make textual interconnections" function is used, open textual interconnections to F blocks may be made without prompting for the F password.
Note on using UDTs
As of PCS 7 V7.0, UDTs are used in the interface in different blocks of the block libraries. This means you can no longer use UDT1 to UDT50 in the user area of the program and in the templates of the master library.
Notes on control modules/control module types
If a project or a library is removed from the multiproject, the associated control modules or control module types cannot be edited further.
When copying a control module type creates a control module, it may occur that the sampling time of the control module is changed. This happens when the default assignment of cyclic interrupt and sampling time has been changed in the library and/or in the target project (for example, when the organization block OB 35, instead of OB 36, has the sampling time 100 ms). In this version, the sampling time is not checked during copying, but rather the assignment to the organization block is maintained. In such cases, please check whether the copied control module has the right sampling time and correct it if necessary.
In this version, 100 ms is always given as the sampling time of a control unit type that has been created from a process tag type, regardless of the cyclic interrupt in which the blocks of the process tag type are installed. Please check whether the created control module type has the required sampling time and correct this if necessary.
Control module types containing no blocks cannot be used as copy templates in projects.
During configuration of control modules and control module types, avoid the use of nested control tags if you wish to exchange the data with COMOS and Advanced ES. Nested control tags are not supported in COMOS and Advanced ES and may lead to problems with these products.
Note on the use of memory cards when loading an S7 program
After loading an S7 program to a memory card (via SIMATIC Manager, menu “CPU > Save to memory card…), please note that the blocks cannot be monitored in test mode of the CFC. When the I/Os are registered, an error message appears informing you that the I/O cannot be monitored. To remedy this, load the program additionally via the CFC to a PLCSim or a test CPU. You will then be able to use test mode as normal.
2.3        CFC for S7
Creating CFC Block Types:
For control module types, when an instance is created, the name of the control module type can be inherited by the names of the blocks in the instance. In the case of optional blocks, however, this inheritance of the type name is not possible.
You can find the manuals as electronic documents which you can read and print with Acrobat Reader (via the Start menu of Windows in the sub-menus SIMATIC and Documentation).
Update 2 contains the following expansions and corrections:
1.        The function “Save as…” with the set option “With reorganization (slow)” now also works correctly when the project contains control modules.
In addition to this update, Update 2 for Plant Hierarchy (PH) V8.0 or a newer update for this version must be installed.
2.        Compilation of an OS now also works in all cases in which interconnections exist between blocks from the Advanced Process Library and chart I/Os.
3.        Compilation of a program is now also successful when multiple interconnections are used.
4.        As of version 2008 of the AS RTX CPU type, now programs that use SFCs 131 to136 can also be loaded.
5.        The following only applies to projects using the Route Control add-on package: Plants with numerous nested units can now also be imported.
6.        Sporadically reported data access errors during configuration in CFC (e.g. when editing, compiling, in test mode) no longer occur.
7.        Canceling the “Book Back Process Objects” process now no longer results in an access conflict during the next download procedure.
8.        The performance problem when generating the code of an F system program has been corrected.
9.        A @CPU_RT system chart is now also generated when channel driver blocks from the F system library are used.
10.        Changes from the output end operand interconnections on SFCs are now also included in delta compiling.
11.        The number of configured process objects of a program is now correctly transferred from the predecessor version during migration.
12.        The “Generate module driver” function now supports Profinet devices that are integrated by means of the "BASED_ON_GSD_FILE" attribute.
13.        Interconnections from control tags with “VarInOut” I/O type are now supported in the editor for technological I/Os.
14.        Blocks of a process tag type sometimes were assigned a color code for their association with a control module type. This has been corrected.
15.        If variants are selected for a control module, the execution sequence defined for the associated blocks in the control module type is now taken into account.
16.        The navigation from the “Properties” dialog (using the “Technological assignments” button) of a message I/O (e.g. MsgEvID) to its message object in the editor for technological I/Os has been corrected.
17.        The “Signal” attribute of a control tag assigned to a block I/O interconnected with a signal is now updated when the name of the signal has been changed in the symbol table.
18.        Inconsistencies occurred in the database when generating control module types or control modules. This resulted in problems when synchronizing the control modules and has been corrected.
19.        When control module types are created from process tag types, process tag types with I/O names containing special characters (e.g. period) are now supported.
20.        The following only applies to the Japanese installation: The “Generate control module type from process tag type” function no longer causes the application to close.
21.        The jump buttons in the faceplate of blocks from the APL now take you to the requested faceplate of the respective APL block even when there are multiple interconnections.
22.        If the default names were retained when lower-level control modules were created in version V8.0, these lower-level control modules can no longer be assigned during a synchronization after the migration of the project data to version V8.0.2. To remedy this problem, the lower-level control modules must be explicitly renamed.
23.        The number of configured process objects is now managed correctly also when chart copies (e.g. process tag types) are used when a new program is created.
24.        When you copy CFC charts across AS with interconnections at the input ends, text references will be created once again at the inputs if these interconnections are not part of the copied content.
GMT+8, 2026-9-19 18:50
