用户名  找回密码
帖子
[PLC编程] SIMATIC CFC V8.0
山海致远 发表于 2019-3-7 22:48:45 | 显示全部楼层 |阅读模式
SIMATIC CFC介绍和安装文件下载网址
可提供此软件远程安装服务,详情查看以下网址内容:
SIMATIC CFC V8.0
Please read the notes carefully; they contain important information on installing and using CFC.
Contents
4        Installation
4.1        Installing CFC
4.2        CFC License Key
4.3        Uninstalling CFC
1.1        What is New?
2.3        CFC for S7
2.4         SFC Instances in the CFC
3.1                Functions with an implementation which differs from the documentation
The CFC can be run on the following operating systems:
    • MS Windows XP Professional SP3
    • MS Windows Server 2003 SP2 Standard
    • MS Windows Server 2003 R2 SP2
    • MS Windows 7 Ultimate 32 Bit
    • MS Windows 7 Ultimate 64 Bit
    • MS Windows Server 2008 32 Bit
    • MS Windows Server 2008 R2 64 Bit
    • MS Windows 7 Professional 32 Bit
    • MS Windows 7 Professional 64 Bit
    • MS Windows Vista 32 Bit Ultimate
    • MS Windows Vista 32 Bit Business
Note: MS Windows XP Home and MS Windows 2000 operating systems are not supported.
SIMATIC CFC V8.0
        Order number:  6ES7658-1EX08-2YA5
        This product package includes:
    • 1 CD TIA Engineering Toolset V8.0
    • 1 license key memory stick
    • 1 certificate of license
SIMATIC CFC Upgrade V7.1 -> V8.0
Order number: 6ES7658-1EX08-2YE5
Contents of the TIA Engineering Toolset CD including CFC
    • CFC V8.0
    • Minimum 600 MHz processor
CFC is a 32-bit application which requires one of the operating systems listed above.
    • Basic software STEP 7 V5.4 SP5 or higher
    • If using CFC for M7:
Note:
The CFC setup itself installs the required SCL compiler functionality with the suitable version (it does not need an SCL license key).
If you installed an SCL compiler with version V5.1.x on the PC, the SCL compiler
must be reinstalled after you have removed the CFC. Otherwise the SCL sources
will no longer be displayed in the SIMATIC Manager.
            You need a PDF Reader compatible with PDF 1.x to read the supplied PDF files.
CFC V8.0 requires approximately 80 Mbytes of space on your hard disk.
4        Installation
4.1        Installing CFC
When you install CFC V8.0, you can overwrite an existing installation of CFC.
4.2        CFC License Key
Before you can start working with CFC, you must transfer the license key from the license key memory stick to the computer.
If the license key cannot be installed during setup, continue the Setup program without installing the license key. Perform a restart and install the license key via the Start menu entry Simatic > License Management > Automation License Manager.
        Important Note:
        Use the Microsoft Windows application "Add/Remove Programs" (in the taskbar via the Start menu entry Settings > Control Panel > Add/Remove Programs) to remove your software package (for example, "SIMATIC CFC V8.0"). This is the only way to uninstall software in Microsoft Windows.
Note:
Since 10/01/2003, the SIMATIC M7 automation computer and all the associated components have been discontinued. Although the M7 is still available as a PLC in the engineering system, it has been removed from the documentation and support is no longer provided. You can find additional information under http://support.automation.siemens.com/WW/view/en/14044569.
1.1        What is New ?
Version V8.0 contains the following enhancements or changes compared to the previous version V7.1.2:
    • Fine-grained operating rights
You can use the new "Op_Level" attribute to configure levels of operator control permissions for a block type.
    • Block encryption
CFC supports the encryption of blocks. Functions (FCs) and function blocks (FBs) can be encrypted. During compiling/loading, an encryption is recognized as a change and the respective block or function is replaced.
    • License consumption for process objects
More than one license or no license at all can now be booked for the use of process objects depending on the functionality of the block type.
    • New concept for process tag types and process tags
In addition to process tag types and process tags, control module types and control modules are now also available. These now also support instance-specific changes and multiple variants of process tag types during synchronization of process tags. Extended data exchange with PCS 7 Advanced ES is also possible.
Data created with older CFC versions can still be used as follows in CFC V8.0:
    • The CFC V3.x to CFC V7.x data can be read and displayed with CFC V8.0.
Data created with CFC V1.0 or CFC V1.1 can still be used as follows in CFC V8.0:
    • The CFC V1.x data can be read and displayed with CFC V8.0. Direct editing of CFC V1.x data is not possible here. If you want to edit V1.x data, proceed as follows:
    • Open the project in the SIMATIC Manager and save it under a different name using the menu command File > Save As... and the option "Rearrange before saving (slow)" and select the file type "Project" in the dialog box which appears. The data is then automatically converted to V8 format.
    • You cannot "reconvert" V8 data back to previous versions.
    • After upgrading from older CFC versions, a series of function blocks are replaced in the program by new versions. The old blocks remain in the block container but can be removed with the menu command Options > Block Types > Clean Up.
CFC V8.0 still takes upper and lower case symbols into account for blocks in charts; in other words, you can create blocks with the same name which differ only in the case used. However, we recommend that you use different names to avoid problems in the future.
Message "Key already exists" when migrating older projects to CFC version V8.0
Differences in CPU protection
    • In the CFC test mode, write access is also permitted with the key switch set to RUN.
Note of AS-wide interconnections
        With version 7.1.1 we have made changes in the code of the IK_SEND system block. If you upgrade your project directly from version V7.1: You can accept this later version of the IK_SEND in your program by proceeding as follows:
o        Open the CFC library in SIMATIC Manager and select the FC155 (IK_SEND) in the "IK" block folder of the S7 program.
o        Execute the function "Options > Charts > Update block types", while you select all projects that use AS-wide interconnections in the following dialog.
Note of textual interconnections in F programs
When the "Make textual interconnections" function is used, open textual interconnections to F blocks may be made without prompting for the F password.
Note on using UDTs
As of PCS 7 V7.0, UDTs are used in the interface in different blocks of the block libraries. This means you can no longer use UDT1 to UDT50 in the user area of the program and in the templates of the master library.
Notes on control modules/control module types
If a project or a library is removed from the multiproject, the associated control modules or control module types cannot be edited further.
When a control module is created by copying a control module type, it may occur that the sampling time of the control module is changed. This happens when the default assignment of cyclic interrupt and sampling time has been changed in the library and/or in the target project (for example, when the organization block OB 35, instead of OB 36, has the sampling time 100 ms). In this version, the sampling time is not checked during copying, but rather the assignment to the organization block is maintained. In such cases, please check whether the copied control module has the right sampling time and correct it if necessary.
In this version, 100 ms is always given as the sampling time of a control unit type that has been created from a process tag type, regardless of the cyclic interrupt in which the blocks of the process tag type are installed. Please check whether the created control module type has the required sampling time and correct this if necessary.
Control modules and control module types containing hierarchical charts are not supported in this version. For this reason, control module types cannot be created from process tag types containing hierarchical charts.
Control module types containing no blocks cannot be used as copy templates in projects.
Note on the use of memory cards when loading an S7 program
After loading an S7 program to a memory card (via SIMATIC Manager, menu “CPU > Save to memory card…), please note that the blocks cannot be monitored in test mode of the CFC. When the I/Os are registered, an error message appears informing you that the I/O cannot be monitored. To remedy this, load the program additionally via the CFC to a PLCSim or a test CPU. You will then be able to use test mode as normal.
2.3        CFC for S7
Creating CFC Block Types:
The manuals are available as electronic documentation and can be displayed and printed with the Acrobat Reader which is supplied with the software (via the Start menu entry Simatic > Documentation).
These notes take precedence over information provided in the manuals and the online help.
    • Correction to the chapter "Editing of control module types", section "Display in the CFC editor"
The sentence
In the following dialog box “Color settings” select the object “Assigned technological connections” under “Objects”
should read:
In the following dialog box “Color settings” select the object “Blocks and I/Os of the control module type” under “Objects”.
    • Correction to the chapter "Editing of control module types”, section “Display in the CFC editor"
This section asserts that the objects of a control module can have different colors. This is incorrect. All objects of a control module have the same color.
GMT+8, 2025-4-3 18:29
