[PLC编程] SIMATIC CFC V7.1
山海致远 发表于 2019-3-7 20:59:49 | 显示全部楼层 |阅读模式
SIMATIC CFC介绍和安装文件下载网址
文件版本过于陈旧,请参考上面网址获取较新版本,若需要此旧版本可以留言回复。
The CFC can be run on the following operation systems:
    • MS Windows 2000 SP4 (referred to as MS Windows 2000 below)
    • MS Windows XP Professional SP3 (referred to as MS Windows XP below)
    • MS Windows Server 2003 SP2 Standard edition with or without R2 as workplace computer
    • MS Vista 32 Bit Ultimate SP1
Notice: MS Windows XP Home operating system is not supported.
SIMATIC CFC V7.1
        Order number:  6ES7658-1EX17-2YA5
        This product package includes:
    • 1 CD TIA Engineering Toolset V7.1
    • 1 license key memory stick
    • 1 certificate of license
        SIMATIC CFC V7.1 Upgrade from V7.0 to V7.1
        Order number:  6ES7658-1EX17-2YE5
    • 1 license key memory stick (with upgrade license)
Contents of the TIA Engineering Toolset CD including CFC
    • CFC V7.1
    • File "CFC-Whatsnew.wri"
    • Minimum 600 MHz processor
    • CFC is a 32-bit application that requires MS Windows 2000 or MS Windows XP or MS Windows Server 2003 or MS Vista 32 Bit Ultimate SP1 as the operating system.
    • Basic software STEP 7 V5.3 or higher
    • If using CFC for M7:
Note:
The CFC setup itself installs the required SCL compiler functionality with the suitable version (it does not need an SCL license key).
If you installed an SCL compiler with version V5.1.x on the PC, the SCL compiler
must be reinstalled after you have removed the CFC. Otherwise the SCL sources
will no longer be displayed in the SIMATIC Manager.
CFC V7.1 requires approximately 60 Mbytes of space on your hard disk.
4        Installation
4.1        Installing CFC
When you install CFC V7.1, you can overwrite an existing installation of CFC.
4.2        CFC License Key
Before you can start working with CFC, you must transfer the license key from the license key memory stick to the computer.
If the license key cannot be installed during setup, continue the Setup program without installing the license key. Perform a restart and install the license key via the start menu item Start > Simatic > License Management > Automation License Manager.
4.3        Uninstalling CFC
        Important Note:
        Use the Microsoft Windows application "Add/Remove Programs" (in the taskbar under Start > Settings > Control Panel > Add/Remove Programs) to remove your software package (for example, "SIMATIC CFC V7.1"). This is the only way to uninstall software in Microsoft Windows.
1.1        What is New ?
For more information, read the topic "What's New?" in the online help. You can call this topic from the contents page of the Help on CFC (menu command Help > Contents;  CFC for SIMATIC S7 ).
You will also find this information on the installation CD in the file "CFC-Whatsnew" and following installation with START > Simatic > Product Notes.
Data created with older CFC versions can still be used as follows in CFC V7.1:
    • The CFC V3.x to CFC V6.0 data can be read and displayed with CFC V7.x.
Data created with CFC V1.0 or CFC V1.1 can still be used as follows in CFC V7.1:
    • The CFC V1.x data can be read and displayed with CFC V7.x. Direct editing of CFC V1.x data is not possible here. If you want to edit V1.x data, proceed as follows:
    • Open the project in the SIMATIC Manager and save it under a different name using the menu command File > Save As... and the option "Rearrange before saving (slow)" and select the file type "Project" in the dialog box which appears. The data is then automatically converted to V7 format.
    • You cannot "reconvert" V7 data back to previous versions.
    • After upgrading from older CFC versions, a series of function blocks are replaced in the program by new versions. The old blocks remain in the block container but can be removed with the menu command Options > Block Types > Clean Up.
CFC V7.x still takes upper and lower case symbols into account for blocks in charts; in other words, you can create blocks with the same name which differ only in the case used. However, we recommend that you use different names to avoid problems in the future.
Message "Key already exists" when migrating older projects to CFC version V7.x
Differences in CPU protection
    • In the CFC test mode, write access is also permitted with the key switch set to RUN.
Note of AS-wide interconnections
    • AS-wide interconnections can only be configured with CP 443-1EX10 or a later version.
    • S7 program names must be unique in the multiproject if you use AS-wide interconnections.
    • The fastest possible cycle time for an AS-wide interconnection is 200 ms and not 100 ms as stated in the online help and in the "Setting up AS-wide interconnections" section of the manual.
Note on Forcing function
If you disable the option “Support forcing” in the dialog box “Object Properties > Extended“ for the chart folder, the forcing settings will be retained but are ineffective when you upload the program to the AS. When you enable the “Support forcing” option once again, all forcing settings will be effective the next time you upload the program to the AS.
In this way you can restart an earlier commissioning session with the same forcing settings.
2.3        CFC for S7
Creating CFC Block Types:
2.4        SFC Instances in the CFC
The manuals are available as electronic documentation and can be displayed and printed with the Acrobat Reader which is supplied with the software (Start > Simatic > Documentation).
GMT+8, 2025-12-15 13:16
