[PLC编程] SIMATIC CFC V7.0 安装文件下载
山海致远 发表于 2019-3-7 20:49:30 | 显示全部楼层 |阅读模式
版本较老,适合老系统的学习用途。
安装文件下载
SIMATIC CFC介绍和其他更多版本安装文件下载网址
SIMATIC CFC V7.0
Please read the notes carefully; they contain important information on installing and using CFC.
If you print the file, make sure that the left and right margins are set to a width of 25 millimeters (approximately 1 inch) for A4 portrait.
Contents
4        Installation
4.1        Installing CFC
4.2        CFC License Key
4.3        Uninstalling CFC
1.1        What is New?
2.3        CFC for S7
2.4   SFC Instances in the CFC
CFC V7.0
        Order number:  6ES7658-1EX07-2YA5
        This package contains the following:
    • 1 CD
    • License Key Disk UPGRADE
    • 1 Certificate of License
CFC V7.0 Upgrade
        Order number:  6ES7 658-1EX07-2YE5
    • 1 CD
Contents of the CFC CD
    • CFC V7.0
    • File "CFC-Whatsnew.wri"
The CFC can be run on the following operation systems:
    • MS Windows 2000 Professional and SP3 or higher (subsequently called MS Windows 2000)
    • MS Windows XP Professional with SP1 or SP1a or SP2 (subsequently called MS Windows XP)
    • MS Windows Server 2003
Notice: MS Windows XP Home operating system is not supported.
    • Minimum 600 MHz processor
CFC is a 32-bit application that requires MS Windows 2000 or MS Windows XP or MS Windows Server 2003 as the operating system.
    • Basic software STEP 7 V5.4 incl. SP1 or higher
    • If using CFC for M7:
Note:
The CFC setup automatically installs the necessary SCL Compiler functionality(no SCL License Key is necessary).
If an SCL compiler previous to than V5.3 SP1 was installed on the computer and the SCL is being uninstalled, the CFC has to be reinstalled. Otherwise you cannot
If you installed an SCL compiler with version V5.1.x on the PC, the SCL compiler must be reinstalled after you have removed the CFC. Otherwise the SCL sources will no longer be displayed in the SIMATIC Manager.
CFC V7.0 requires approximately 60 Mbytes of space on your hard disk.
4        Installation
4.1        Installing CFC
When you install CFC V7.0, you can overwrite an existing installation of CFC.
4.2        CFC License Key
Before you can start working with CFC, you must transfer the license key from the License Key Disk to the computer. There are two ways of doing this:
    • While you are installing CFC, the Setup program displays a message if there is no suitable license key installed on your computer. You can then decide whether you want the license key to be installed by the Setup program or whether you want to install the license at a later time using the to-be-installed Automation License Manager program.
    • If the license key cannot be installed during setup, continue the Setup program without installing the license key. Perform a restart and install the license key via the start menu item Simatic\License Management\Automation License Manager.
        Important Note:
        Use the Microsoft Windows application "Add/Remove Programs" (in the taskbar under Start > Settings > Control Panel > Add/Remove Programs) to remove your software package (for example, "SIMATIC CFC V7.0"). This is the only way to uninstall software in Microsoft Windows.
1.1        What is New ?
For more information, read the topic "What's New?" in the online help. You can call this topic from the contents page of the Help on CFC (menu command Help > Contents;  CFC for SIMATIC S7 ).
You will also find this information on the installation CD in the file "CFC-whatsnew" and following installation with START > Simatic > Product Notes.
Data created with older CFC versions can still be used as follows in CFC V7.0:
    • The CFC V3.x to CFC V6.0 data can be read and displayed with CFC V7.0.
Data created with CFC V1.0 or CFC V1.1 can still be used as follows in CFC V7.0:
    • The CFC V1.x data can be read and displayed with CFC V7.0. Direct editing of CFC V1.x data is not possible here. If you want to edit V1.x data, proceed as follows:
    • Open the project in the SIMATIC Manager and save it under a different name using the menu command File > Save As... and the option "Rearrange before saving (slow)" and select the file type "Project" in the dialog box which appears. The data is then automatically converted to V7 format.
    • You cannot "reconvert" V7.0 data back to previous versions.
CFC V7.0 still takes upper and lower case symbols into account for blocks in charts; in other words, you can create blocks with the same name which differ only in the case used. However, we recommend that you use different names to avoid problems in the future.
Message "Key already exists" when migrating older projects to CFC version V7.0
Differences in CPU protection
    • In the CFC test mode, write access is also permitted with the keyswitch set to RUN.
2.3        CFC for S7
Creating CFC Block Types:
The manuals are available as electronic documentation and can be displayed and printed with the Acrobat Reader which is supplied with the software (Start > Simatic > Documentation).
GMT+8, 2025-4-2 02:38
