[PLC编程] SIMATIC CFC V6.1 SP1
山海致远 发表于 2019-3-7 20:40:42 | 显示全部楼层 |阅读模式
安装文件下载:仅供个人在家学习测试用途 不得用其他用途,否则后果自负未经测试,稳定性可靠性功能性未知
SIMATIC CFC介绍和安装文件下载网址
SIMATIC CFC V6.1 incl. Service Pack 1
Please read the notes carefully; they contain important information on installing and using CFC V6.1 incl. Service Pack 1 (SP1).
If you print the file, make sure that the left and right margins are set to a width of 25 millimeters (approximately 1 inch) for A4 portrait.
Contents
1        Contents of the Consignment        1
2        Hardware Requirements        2
3        Software Requirements        2
3.1        Operating Environment        2
3.2        Memory Requirements        3
4        Installation        3
4.1        Installing CFC V6.1 incl. SP1        3
4.2        CFC V6.1 License Key        3
4.3        Uninstalling CFC V6.1 incl. SP1        3
4.4        Installing the Borland C Compiler (for M7)        3
1        New Features and Modifications in the New Version        4
1.1        What is New in Version 6.1 ?        4
2        Notes on Configuring and Operating the Software        4
2.1        Data from Different Versions of CFC        4
2.2        General Information        4
2.3        CFC for S7        5
3        Notes on Documentation        5
The installation notes contain important information that you will require to install CFC V6.1 incl. SP1. Read these notes before installing the software.
CFC V6.1 incl. SP1
        Order number:  6ES7658-1EX16-2YA5
        This package contains the following:
    • 1 CD
    • License Key Disk UPGRADE
    • 1 Certificate of License
CFC V6.1 incl. SP1 Upgrade
        Order number:  6ES7 658-1EX16-2YE5
    • 1 CD
Contents of the CFC CD
    • CFC V6.1 incl. SP1
    • File "CFC-Whatsnew.wri"
The CFC can be run on the following operation systems:
    • MS Windows 2000 Professional and SP3 or higher (subsequently called MS Windows 2000)
    • MS Windows XP Professional with SP1 or SP1a or SP2 (subsequently called MS Windows XP)
    • MS Windows Server 2003
Notice: MS Windows XP Home operating system is not supported.
    • Minimum 600 MHz processor
CFC V6.1 incl. SP1 is a 32-bit application that requires MS Windows 2000 or MS Windows XP or MS Windows Server 2003 as the operating system.
    • Basic software STEP 7 V5.3 or higher
    • If using CFC for M7:
Note:
The CFC setup automatically installs the necessary SCL Compiler functionality
(no SCL License Key is necessary).
CFC V6.1 incl. SP1 requires approximately. 60 Mbytes of space on your hard disk.
4        Installation
When you install CFC V6.1 incl. SP1, you can overwrite an existing installation of CFC.
Before you can start working with CFC, you must transfer the license key from the License Key Disk to the computer. There are two ways of doing this:
    • While you are installing CFC, the Setup program displays a message if there is no suitable license key installed on your computer. You can then decide whether you want the license key to be installed by the Setup program or whether you want to install the license at a later time using the to-be-installed Automation License Manager program.
    • If the license key cannot be installed during setup, continue the Setup program without installing the license key. Perform a restart and install the license key via the start menu item Simatic\License Management\Automation License Manager.
        Important Note:
        Use the Microsoft Windows application "Add/Remove Programs" (in the taskbar under Start > Settings > Control Panel > Add/Remove Programs) to remove your software package (for example, "SIMATIC CFC V6.1 + SP1"). This is the only way to uninstall software in Microsoft Windows.
This also applies to some files created dynamically by CFC. This is recognized by the uninstall tool and reported with the message "Some elements could not be removed. You should manually remove items related to the application." You can then decide whether or not you want to delete these files.
For more information, read the topic "What's New?" in the online help. You can call this topic from the contents page of the Help on CFC (menu command Help > Contents; Introduction to CFC ).
You will also find this information on the installation CD in the file "CFC-whatsnew" and following installation with START > Simatic > Product Notes.
Data created with older CFC versions can still be used as follows in CFC V6.1:
    • The CFC V3.x to CFC V6.0 data can be read and displayed with CFC V6.1.
Data created with CFC V1.0 or CFC V1.1 can still be used as follows in CFC V6.1:
    • The CFC V1.x data can be read and displayed with CFC V6.1. Direct editing of CFC V1.x data is not possible here. If you want to edit V1.x data, proceed as follows:
    • Open the project in the SIMATIC Manager and save it under a different name using the menu command File > Save As... and the option "Rearrange before saving (slow)" and select the file type "Project" in the dialog box which appears. The data is then automatically converted to V6.x format.
    • You cannot "reconvert" V6.1 data back to previous versions.
CFC V6.1 still takes upper and lower case symbols into account for blocks in charts; in other words, you can create blocks with the same name which differ only in the case used. However, we recommend that you use different names to avoid problems in the future.
Message "Key already exists" when migrating older projects to CFC version V6.1
Differences in CPU protection
    • In the CFC test mode, write access is also permitted with the keyswitch set to RUN.
2.3        CFC for S7
Creating CFC Block Types:
The manuals are available as electronic documentation and can be displayed and printed with the Acrobat Reader which is supplied with the software (Start > Simatic > Documentation).
GMT+8, 2025-4-2 02:37
