[工业机器人] KUKA Sim Tech 2.2.2 & KUKA Sim Library 2.2.2
山海致远 发表于 2019-3-6 16:09:22 | 显示全部楼层 |阅读模式
下载链接:
  KUKA.Sim 2.2.2
                    Copyright (c) 2012 KUKA Roboter GmbH
                           All rights reserved.
                              October, 2012
System Requirements:
   WIN XP or WIN 7
Released for:
   KUKA.Sim Layout 2.2
   KUKA.Sim Tech 2.2
   KUKA.Sim Pro 2.2
Version 2.2.2 Build09
Changes / Fixed:
General                        New KUKA End User License Agreement (EULA)
Implementation        Unable to get the extended property value of layout item type "LayoutPropertyList" after saving and re-opening the layout
Implementation         Critical crash fix - When using "saveLayoutToUri" command
Implementation         Minimum distance calculation fix
Implementation         Kinchain invalid solution error fix
Implementation         Kinchain state fix to speed and acceleration overshoots in trajectory
Implementation        Huge text support for string variable
Implementation         Python: Raycast wrapper fix
Implementation         Another minimum distance calculation fix
Implementation         Lock symbol can be hidden by turning off a layer
Implementation        Minimum distance and collision calculation optimization
COM                                Node Offset/Joint/Pivot expressions value available as extended value
COM                                Component wrapper memory leak fixed
COM                                Joint update speed improvements - Kinchain prefers initial joint values over solution joint values improving trajectory calculation
CAD Reading                CoreTech CAD Loader replaced with HOOPS Exchange CAD Loader (not supported by KUKA.Sim Layout 2.2)
CAD Reading                Some healing functions included in the HOOPS Exchange implementation
Version 2.2.1 Build08
Changes / Fixed:
CAD Reading                Access violation while reading a step file
CAD Reading                CAD colors importing error with prt file type
CAD Reading                Loading big cad files causes errors
CAD Reading                Memory errors during CAD loading
CAD Reading                STL loading issues
CAD Reading                Wrong extension for component after loading a geometry
COM                                Crash after deleting a component with PnP created through COM
COM                                getConfigWarning returns unreachable for singular points
COM                                Incorrect license key returned by API
COM                                IvcFastPolygonSet.addPointsInWorld() gives invalid argument runtime exception
COM                                IvcMotionInterpolator.getCycleTimeAtTarget(-1) returns old target
COM                                IvcProperty RebuildOnChange or UpdateOnChange not available in COM
COM                                'Network License' returned instead of a product key
COM                                Rsl points wrongly named when created through COM
COM                                Unreachable points throw exception in COM
GUI                                'Display Name' not displayed completely
GUI                                Geometry options German strings not fitting the control
GUI                                Inputbox TransRot character value limitation
GUI                                Material editor not translated to German
GUI                                Materials options German strings not fitting the control
GUI                                New eCat path not visible in Tools Options dialog
GUI                                No control over hiding frames during navigation
GUI                                Process menu name limited to 7 characters
GUI                                Registration dialog explanation not complete
GUI                                Several German translation issues
GUI                                Wrong link in the registration dialog
GUI                                Wrong product name displayed in the registeration dialog
Implementation        Bogus collision reported
Implementation        Component selection dropdown control crash
Implementation        Crash when clearing a model
Implementation        Crash when closing
Implementation        Crash when deleting a component
Implementation        Crash when loading a layout
Implementation        Crash when measuring distances
Implementation        Different results when testing first collisions between lists
Implementation        Error in closing Set Node window
Implementation        Error in saving a big model
Implementation        Fill not working properly
Implementation        Motion nodes displayed as unreachable for robot even though within reach
Implementation        Motion Path Objects not visible
Implementation        Near miss not working properly
Installer                Python25 installed on wrong location
Installer                SP1 was displayed by the installer or title bar
Installer                Uninstaller did not remove all postprocessor templates
Installer                Wrong COM registration CLSIDs
Installer                Wrong help file displayed
KRC Page                KRC        Crash when loading unregocnized syntax from dat file
KRC Page                KRC        Download with DefineBase returns incorrect number
KRC Page                KRC        Program Changed event leads to communication problem with KUKA Office Lite
KRC Page                 KRC        Unnecessary dialog for *.dat displayed
Licensing                Abstract Interface and IO mapping installer error
Licensing                Connection to network license server lost in pc standby mode
Licensing                Crash when trying to activate an empty product key
Licensing                Deactivation allows to cancel even if it is not possible
Licensing                License Key field difficult
Licensing                Manual registration to community not working
Licensing                Misleading error messages in license activation
Licensing                Possible to enter empty license keys in license list
Licensing                Unknown licenses cannot be removed
Robotics                Errors moving to PTP points with different configurations
Robotics                Jogging a robot on track keeps tcp location
Robotics                Overhead reachability and RSL motion execution errors in robot
Robotics                Selecting a sequence selects and executes a statement
Robotics                Error in highlighting unreachable points
Robotics                PalletizingMode does not work
Documentation        Errors in screenshots of German manual
Documentation        Loop button missing from manual
Documentation        Missing pictures from manual
                        R E L E A S E    N O T E S
                           KUKA.Sim Library 2.2.2
                              October, 2012
   WIN XP or WIN 7
   KUKA.Sim 2.2 product must be installed
Released for:
   KUKA.Sim Layout 2.2
   KUKA.Sim Tech 2.2
   KUKA.Sim Pro 2.2
New robot types / new components / Enhancements:
        - KR 5 R1400
        - KR 120 R1800 nano
        - KR 160 R1570 nano
        - KL 2000 (linear unit)
        - KR C4 smallsize cabinet
        - New KUKA Positioner
        - New Manufacturers - MRK-Systeme GmbH
Changes / Fixed:
        - New KUKA End User License Agreement (EULA)
        - revise of the linear units (parametric enhancements - pedestal, installation area, etc.)
        - revise of the Quantec Series, incl. Press to Press robots - (K-Box, Flange geometry)
        - revise of the Agilus Series (sixx, fivve) - (Flange geometry)
        - change of the "WristSigularityTolerance" value from 1?to 0.1?in all articulated kinematics components
Discontinuation --> moved to archive:
    - KR5 scara / KR10 scara series
        - KUKA Jet kinematics
-   KR 16-3 S
-        KR 16-3 arc HW
-        KR 16L8-3 arc HW
-        KR 240 R2700 prime
-        KR 100 R3500 press
-        KR 120 R3500 press
-        KR 120 R3200 PA
-        KR 180 R3200 PA
-        KR 240 R3200 PA
-        KR 120 R2700 extra HA
-        KR 90 R2900 extra HA
-        KR 90 R3100 extra HA
-        KR 700 PA arctic
-        KR 6 R700 sixx
-        KR 6 R900 sixx
-         KR 10 R900 sixx
-   KR 10 R1100 sixx
-         KR 6 R700 fivve
-   KR 6 R900 fivve
-   KR 10 R1100 fivve
-         KR 6 R700 fivve C
-   KR 6 R900 fivve C
-   KR 10 R1100 fivve C
-         LBR iiwa 7 R800
-        LBR iiwa 14 R820
-   KR C4 (reworked)
-   KR C4 compact
-        KR C4 compact lr  (Note: only for new LBR iiwa)
-   KR C4 midsize
-        KR C4 extended
-         KR C4 rack
-        Add new pedestal (step range 100 mm)
-        Previous KUKA.Sim 2.2 library installation will be automtically removed
    (no side effects to user data)
-        Windows Installer 4.5 added as a dependency for WIN XP SP3
Changes / Fixed:
-        Mount Tool error (all robot types)
-   Warning: 'with' will become a reserved keyword in Python 2.6 (all robot types - Quantec series)
-   Axis limits A2/A3/A5 changed (all robot types of KR500-3/KR360-3 series)
-        LBR 4+ redundant kinematic fixed
-   Counter balancing systems fixed of KR125 series
-         KR16-2 S
-         KR16-2 KS-S
-         KR16-2 F-S
-         LBR 4+
-        KPF1-MD250
-        KPF1-MD500
-        KPF1-MD750
-        KPF1-MD1000
-        KPF1-MD2000
-        KPF1-MDC250
-        KPF1-MDC500
-        KPF1-MDC750
-        KPF1-MDC1000
-        KPF1-MDC2000
-        KPF1-H250
-        KPF1-H500
-        KPF1-H750
-        KPF1-H1000
-        KPF1-H2000
-        KPF1-H250T
-        KPF1-H500T
-        KPF1-H750T
-        KPF1-H1000T
-        KPF3-V2H250
-        KPF3-V2H500
-        KPF3-V2H750
-        KPF3-V2H1000
GMT+8, 2025-12-15 05:52
