[PLC编程] PacDrive Automation Toolkit EPAS-4 V24 SP3 Version 00.24.03
山海致远 发表于 2019-3-4 15:49:14 | 显示全部楼层 |阅读模式
EPAS-4 puts a simple approach to the powerful IEC language at the disposal of the PLC programmer. Use of the editors and debugging functions is based upon the proven development program environments of advanced programming languages (such as Visual C++).
比较老的软件,适合做老旧设备调试维护,支持windows XP和 windows 7 操作系统
安装文件下载链接:
tools, the Automation Toolkit EPAS-4 is an exemplar for a powerful programming tool, that is easy to handle, just like a standard office program.
The important advantage of EPAS-4 is, that all components are aligned on each other. The profit for the user is: a fast training and easy operation.
If the present CD was ordered as an Automation Toolkit EPAS-4, you will find the activation code on the type plate of the CD.
With the help of the activation code, you can activate EPAS-4 for an absolute application. Without the activation code, the full function of EPAS-4 is only at your disposal for a test period of 90 days.
It is possible to activate the test version with a valid activation code for an absolute application later, without a reinstallation. For this, approach your ELAU contact person.
LIDECHAO 发表于 2019-11-5 15:07:02 | 显示全部楼层
需要ACTIVITY KEY 打开不了
 楼主| 山海致远 发表于 2019-11-5 23:05:46 | 显示全部楼层
需要ACTIVITY KEY 打开不了
不非需要activation code,可以全功能使用90天。
GMT+8, 2026-4-8 05:46
