[运动控制] ELAU PacDrive Diagnostics v2.1 PacDrive控制器故障诊断程序
山海致远 发表于 2019-3-2 18:14:19 | 显示全部楼层 |阅读模式
安装文件下载:此程序发布年代较早(2008年),仅在在windows xp上测试过,其他操作系统兼容性未知。
百度网盘下载链接.txt (754 Bytes, 售价: 15 E币)
Rapid error analysis is a central topic in the automation field. The PacDrive Diagnostics tool offers comprehensive support. All of the service data you need for the PacDrive system can be accessed quickly and completely using the intuitively arranged program screen. You can display data according to your preferences, save it, or forward it directly to a service location.
PacDrive Diagnostics works without an installed EPAS-4 development system and requires only the gateway that was delivered with it to connect to a PacDrive controller. The firmware version is of no importance for the use of this tool. Of course, you can gather more data if you use newer versions. This also improves the diagnostic possibilities.
PacDrive Diagnostics 使用手册 英文版
https://www.eleok.com/thread-122618-1-1.html
Modification Service PacDrive Diagnostics V1.7 - V2.1新增功能
Modification Service PacDrive Diagnostics V1.7 - V2.1.pdf (554.09 KB)
shengxian120 发表于 2021-10-23 22:22:14 | 显示全部楼层
棒棒哒的楼主
GMT+8, 2026-3-19 06:18
