[PLC编程] SIMATIC CFC V6.1 下载
山海致远 发表于 2019-2-13 16:57:09 | 显示全部楼层 |阅读模式
SIMATIC CFC介绍和安装文件下载网址
文件版本过于陈旧,请参考上面网址获取较新版本。
6.1版本安装文件下载:仅提供个人在家学习用途,此程序文件来源于网络可靠性稳定性完整性皆无法验证,禁止用于其他用途,否则后果自负。
百度网盘下载链接.txt (1.3 KB, 售价: 30 E币)
The CFC CD is in 5 languages and run on the following operating systems:
MS Windows 2000 Professional and SP3 or higher (subsequently called MS Windows 2000),
MS Windows XP Professional with SP1 or SP1a (subsequently called MS Windows XP).
Notice: MS Windows XP Home operating system is not supported.
Minimum 600 MHz processor
Minimum 512 MB RAM main memory
CFC V6.1 is a 32-bit application that requires MS Windows 2000 or MS Windows XP as the operating system.
Basic software STEP 7 V5.3 or higher
If using CFC for S7:
S7-SCL V5.1 SP3 or higher
If using CFC for M7:
M7-SYS V2.1, M7-SYS-RT V4.0 or M7-SYS-RT V5.0
MS Windows XP is not supported by M7-SYS, and another operating system must be selected.
Borland C compiler V5.01 (can be supplied by Siemens; Order Number: 6ES7812-1BC01-0AA0)
CFC V6.1 requires approximately. 60 Mbytes of space on your hard disk.
4        Installation
4.1        Installing CFC V6.1
When you install CFC V6.1, you can overwrite an existing installation of CFC.
4.2        CFC V6.1 License Key
Before you can start working with CFC, you must transfer the license key from the License Key Disk to the computer. There are two ways of doing this:
    • While you are installing CFC, the Setup program displays a message if there is no suitable license key installed on your computer. You can then decide whether you want the license key to be installed by the Setup program or whether you want to install the license at a later time using the to-be-installed Automation License Manager program.
    • If the license key cannot be installed during setup, continue the Setup program without installing the license key. Perform a restart and install the license key via the start menu item Simatic\License Management\Automation License Manager.
4.3        Uninstalling CFC V6.1
        Important Note:
        Use the Microsoft Windows application "Add/Remove Programs" (in the taskbar under Start > Settings > Control Panel > Add/Remove Programs) to remove your software package (for example, "SIMATIC CFC V6.1"). This is the only way to uninstall software in Microsoft Windows.
This also applies to some files created dynamically by CFC. This is recognized by the uninstall tool and reported with the message "Some elements could not be removed. You should manually remove items related to the application." You can then decide whether or not you want to delete these files.
1.1        What is New in Version 6.1 ?
For more information, read the topic "What's New?" in the online help. You can call this topic from the contents page of the Help on CFC (menu command Help > Contents; Introduction to CFC ).
You will also find this information on the installation CD in the file "CFC-whatsnew" and following installation with START > Simatic > Product Notes.
Data created with older CFC versions can still be used as follows in CFC V6.1:
    • The CFC V3.x to CFC V6.0 data can be read and displayed with CFC V6.1.
Data created with CFC V1.0 or CFC V1.1 can still be used as follows in CFC V6.1:
    • The CFC V1.x data can be read and displayed with CFC V6.1. Direct editing of CFC V1.x data is not possible here. If you want to edit V1.x data, proceed as follows:
    • Open the project in the SIMATIC Manager and save it under a different name using the menu command File > Save As... and the option "Rearrange before saving (slow)" and select the file type "Project" in the dialog box which appears. The data is then automatically converted to V6.x format.
    • You cannot "reconvert" V6.1 data back to previous versions.
CFC V6.1 still takes upper and lower case symbols into account for blocks in charts; in other words, you can create blocks with the same name which differ only in the case used. However, we recommend that you use different names to avoid problems in the future.
Message "Key already exists" when migrating older projects to CFC version V6.1
Differences in CPU protection
    • In the CFC test mode, write access is also permitted with the keyswitch set to RUN.
2.3        CFC for S7
Creating CFC Block Types:
"CFC Library" block library is overwritten by the new version
Bei der Installtion wird die bestehende Bausteinbibliothek "CFC Library" durch die neue Version überschrieben (diese enthält den korrigierten Baustein R_TRIG). Wenn Sie sich die alte Bibliothek erhalten wollen, muss diese vor der Installation kopiert werden.
The manuals are available as electronic documentation and can be displayed and printed with the Acrobat Reader which is supplied with the software (Start > Simatic > Documentation).
GMT+8, 2026-9-29 22:15
