[PLC编程] SIMATIC CFC V6.0 SP2
山海致远 发表于 2019-1-27 23:58:54 | 显示全部楼层 |阅读模式
安装文件下载:注意:很老的软件,仅提供安装文件,不提供授权,仅供个人在家学习测试用途,具体系统兼容性和安装方法请自行查阅资料,文件来源于网络搜集可靠性安全性完整性稳定性都无法验证,禁止用于其他用途,否则后果自负。
CFC_V6.0_SP2.ZIP (30.75 MB, 售价: 100 E币)
SIMATIC CFC介绍和安装文件下载网址
CFC V6.0 incl. SP2 is a 32-bit application that requires MS Windows 95, MS Windows 98, MS Windows ME, MS Windows NT, MS Windows 2000, or MS Windows XP as the operating system. It cannot run under Microsoft Windows 3.1 or Microsoft Windows for Workgroups 3.11.
We recommend that you also install the Microsoft service pack 1 (Windows 95, version 4.00.950a). You require service pack 5 for Windows NT 4.0 (NT version 4.00.1381). You can find information about these software packages on the Microsoft web site on the Internet.
Basic software STEP 7 V5.1 SP6 or higher
If using CFC for S7:
Programming language S7-SCL V5.0 SP3 or higher or S7-SCL V5.1 SP3 or higher for MS Windows ME, MS Windows 2000, or MS Windows XP
If using CFC for M7:
M7-SYS V2.1, M7-SYS-RT V4.0 or M7-SYS-RT V5.0
Borland C compiler V5.01 (can be supplied by Siemens; Order Number: 6ES7812-1BC01-0AA0)
MS Windows XP is not supported by M7-SYS, and another operating system must be selected.
GMT+8, 2026-7-1 16:29
