[工业通信] SINAUT ST7 Engineering V5.5 with SP3
山海致远 发表于 2019-1-21 20:47:49 | 显示全部楼层 |阅读模式
请先导入压缩包中的Sinaut Enginering v5.5 with SP3.reg文件,然后再运行安装文件。
下载链接:
The following new functions are supported with SINAUT engineering software V5.5 + SP3:
    SINAUT ST7: Support for a proxy functionality for configuring the connection of TIM 1531 IRC in SINAUT engineering software V5.5 + SP3 with an export function for further configuration in TIA Portal V15.
    Adaptation of the SINAUT engineering software to the operating systems supported by STEP 7 V5.6.
System requirements:
    MS Windows 7 Ultimate, Professional and Enterprise (64-bit), with SP1
    MS Windows 10 Pro and Enterprise (64-bit)
    MS Windows Server 2008 R2 (64-bit), with SP1 (standard edition as workstation computer)
    MS Windows Server 2012 R2 (64-bit) (standard edition as workstation computer)
    MS Windows Server 2016 (64-bit) (standard edition as workstation computer)
================== How to install =================================
click to file "Sinaut Enginering v5.5 W7x64.reg" for add keys to Registry
and run Setup.exe
GMT+8, 2025-4-20 13:51
