[PLC编程] S7-200 to S7-1200 Program Converter
山海致远 发表于 2019-1-21 11:19:39 | 显示全部楼层 |阅读模式
s7-200程序转s7-1200程序的工具及说明文档下载
S7-200_to_S7-1200_Program_Converter.zip (4.46 MB, 售价: 10 E币)
SIMATIC S7-200 to SIMATIC S7-1200 Application Software Conversion Tool :
To support the conversion of existing SIMATIC S7-200 Applications to SIMATIC S7-1200 the further on described Software “S7-200 to SIMATIC S7-1200 software conversion tool” can be downloaded.
The STEP 7-Micro/WIN program that you want to convert must have these properties:
The program must have been created using STEP 7-Micro/WIN V4.0 SP7 or an earlier version of STEP 7-Micro/WIN.
The program must have been created using SIMATIC programming mode. IEC programming mode is not supported.
The program must have been saved in LAD (ladder editor) format.
The program must compile with no errors.
All user-defined password block protection must have been removed from the STEP 7-Micro/WIN program. Remove the password protection from the main routine, subroutines, interrupt routines, and all data pages in the data block. Any program block that is password protected will not be converted
For further details, and the Tool handling, please refer to the corresponding documentation, embedded into the zip file.
System Requirments:
The very same conditions for the installation of SIMATIC STEP 7 basic V10.5 are valid. In order to be able to install the S7-200 to S7-1200 application software conversion tools, SIMATIC STEP 7 basic V10.5 SP2 and SIMATIC STEP 7-Micro/WIN V4.0 SP6 (or higher) have to be installed on your computer.
Installation S7-200 zu S7-1200 Applikation Software Konversion Tool:
Download the attached file S7200toS71200Converter.zip.
unzip the file onto your Hard drive.
execute the installation "setup.exe" within the unzipped file.
yaodong07518 发表于 2019-11-13 11:23:28 | 显示全部楼层
为什么扣了工控币,但没有下载到,是什么原因?
qingxuan 发表于 2019-11-13 14:44:40 | 显示全部楼层
您好,您再点击一下附件就可以下载了
GMT+8, 2025-4-3 04:32
