[HMI/SCADA] 光洋工业触摸屏C-more 系列用户手册[第一版]
山海致远 发表于 2018-12-20 22:39:00 | 显示全部楼层 |阅读模式
厂商: 光洋
ViewJetCmore 系列触摸屏是KOYO公司最新推出的新一代工业触摸屏产品部分内容截图:
完整文档下载: 光洋工业触摸屏C-more 系列用户手册[第一版].pdf (7.43 MB, 售价: 2 E币)
目 录
前言 ..................................................................................................................................................1
使用注意事项...................................................................................................................................2
第一章 C-more viewjet软件菜单..........................................................................................3
1-1 文件(F).........................................................................................................................3
1.新建(S) ..................................................................................................................3
2.打开(O)..................................................................................................................8
3.关闭(C)..................................................................................................................9
4.保存(A)..................................................................................................................9
5.另存为(V)..............................................................................................................9
6.锁定保存(P) ........................................................................................................10
7.导入(I) .................................................................................................................10
8.导出(X)................................................................................................................15
9.模拟运行(S) ........................................................................................................22
10.工程传送(R)......................................................................................................25
11.打印(N)..............................................................................................................28
12.打印预览(T) ......................................................................................................29
13.打印设置(U)......................................................................................................29
14.工程信息(J).......................................................................................................30
15.工程选项(T) ......................................................................................................30
16.退出(E) ..............................................................................................................31
1-2 编辑(E).......................................................................................................................31
1.撤消(U)................................................................................................................31
2.重复(R)................................................................................................................32
3.剪切(C)................................................................................................................32
4.复制(P) ................................................................................................................32
5.粘贴(A)................................................................................................................32
6.全选(S) ................................................................................................................32
7.删除(D)................................................................................................................33
8.编辑(E) ................................................................................................................33
9.对齐(I) .................................................................................................................33
10.次序(O)..............................................................................................................36
11.组设定(G)..........................................................................................................38
1-3 视图(V) ......................................................................................................................39
1-4 工具(T).......................................................................................................................48
1-5 对象(O) ......................................................................................................................54
1.图形(S) ................................................................................................................56
2.按钮(B)................................................................................................................74
3.指示灯(I) ...........................................................................................................100
4.输入(E) ..............................................................................................................109
5.仪表/曲线图(M)................................................................................................119
6.Bitmap图形(T) ..................................................................................................133
7.配方(R)..............................................................................................................144  2
8.报警(A)..............................................................................................................151
9.文本(X)..............................................................................................................155
10.时钟(C)............................................................................................................167
11.控制(O)............................................................................................................171
12.系统(Y)............................................................................................................178
1-6 画面(S).....................................................................................................................191
1.新建画面(N)......................................................................................................191
2.画面删除(D)......................................................................................................192
3.画面改名(R)......................................................................................................192
4.画面复制(C)......................................................................................................193
5.画面粘贴(P) ......................................................................................................193
6.画面选项(S) ......................................................................................................193
1-7 数据库(D) ................................................................................................................195
1.变量数据库(T) ..................................................................................................195
2.消息数据库(M).................................................................................................197
3.事件管理数据库(E) ..........................................................................................202
4.地址薄(A)..........................................................................................................208
5.配方数据库.............................................................................................................211
6.键盘定义(D)......................................................................................................211
1-8 设置(U) ....................................................................................................................214
1.触摸屏管理器(P)...............................................................................................214
2.密码设置(C)......................................................................................................215
3.语言设置(L) ......................................................................................................216
4.时钟设定(O)......................................................................................................216
5.PLC<->触摸屏(A).............................................................................................218
6.报警记录保护(R)..............................................................................................222
7.触摸屏网络设定(T) ..........................................................................................223
1-9 触摸屏(P).................................................................................................................227
1.触摸屏信息(P)...................................................................................................227
2.显示画面(D)......................................................................................................228
3.触摸屏重启(R)..................................................................................................228
4.时钟校准(A)......................................................................................................229
5.存储器清除(M).................................................................................................230
6.数据保护(T) ......................................................................................................230
7.系统程序更新(U)..............................................................................................230
第二章 通讯列表.......................................................................................................................231
一.C-more系列触摸屏目前所支持的各家PLC型号一览表: ..........................................231
1.KOYO DirectLOGIC PLC......................................................................................231
2.Modicon ..................................................................................................................233
3.Modbus TCP/IP.......................................................................................................233
4.Allen-Bradley..........................................................................................................234
5.GE ...........................................................................................................................234
6.Mitsubishi................................................................................................................234
7.Omron .....................................................................................................................235  3
8.Keyence...................................................................................................................235
9.Matsushita ...............................................................................................................236
10.Generic EtherNet/IP..............................................................................................236
11.Sharp .....................................................................................................................236
12.Siemens .................................................................................................................236
13.Toshiba..................................................................................................................237
14.JTEKT...................................................................................................................237
15.Yaskawa................................................................................................................237
16.Yokogawa .............................................................................................................238
17.RKC ......................................................................................................................238
18.Yamatake ..............................................................................................................238
二.各家PLC功能存储器表及电缆连接图........................................................................239
1.DirectLogic K-Sequence /DirectNet/以太网(S Operand) – 功能存储器..............239
2.DirectLogic Modbus (Koyo地址) (S Operand) –功能存储器 ...............................241
3.DirectLogic DirectNet (for DL330/340) – 功能存储器 ........................................242
4.Modbus RTU和Modbus TCP/IP-功能存储器 .......................................................244
5.DirectLogic K-协议/CCM2 (S 系列/DL系列) – 电缆连接图 .............................244
6.Modbus RTU – 电缆连接图..................................................................................247
7.Allen-Bradley DF1 Micrologix (Full duplex)-功能存储器....................................248
8.Allen-Bradley DF1 Micrologix (Full duplex)-电缆连接图....................................249
9.Allen-Bradley DF1 SLC500 (Full Duplex)-功能存储器........................................250
10.Allen-Bradley DF1 SLC500 (Full Duplex)-电缆连接图......................................251
11.Allen-Bradley DF1 PLC5-功能存储器 ................................................................251
12.Allen-Bradley DF1 PLC5-电缆连接图 ................................................................252
13.Allen-Bradley DF1 SLC500/MicroLogix (Half duplex)-功能存储器 .................252
14.Allen-Bradley DF1 SLC500/MicroLogix (Half duplex)-电缆连接图 .................254
15.Allen-Bradley DH485/AIC SLC500/MicroLogix-功能存储器 ...........................254
16.Allen-Bradley DH485/AIC SLC500/MicroLogix-电缆连接图 ...........................256
17.Entivity (Think&Do) Modbus – 电缆接线图......................................................256
18.GE 90/30 SNPX – 功能存储器 ...........................................................................258
19.GE 90/30 SNPX – 电缆连接图 ...........................................................................259
20.Mitsubishi Melsec FX-功能存储器......................................................................259
21.Mitsubishi Melsec FX-电缆连接图......................................................................260
22.Mitsubishi AnA AnU – 功能存储器 ...................................................................260
23.Mitsubishi AnA AnU – 电缆连接图 ...................................................................261
24.Mitsubishi AnN_AnS – 功能存储器...................................................................262
25.Mitsubishi AnN_AnS – 电缆连接图...................................................................263
26.Mitsubishi QnA – 功能存储器............................................................................264
27.Mitsubishi QnA –电缆连接图..............................................................................265
28.Mitsubishi 以太网 – 功能存储器......................................................................267
29.Mitsubishi_QnA_以太网 – 功能存储器............................................................269
30.Mitsubishi FX0 系列 – 功能存储器...................................................................269
31.Mitsubishi FX0 系列 – 电缆连接图...................................................................270
32.Mitsubishi FX2 系列 – 功能存储器..................................................................271  4
33.Mitsubishi FX2 系列 – 电缆连接图..................................................................272
34.Mitsubishi Q 系列 – 功能存储器......................................................................273
35.Mitsubishi Q 系列 – 电缆连接图......................................................................274
36.Omron_Host_Link_Adapter – 功能存储器.........................................................274
37.Omron_Host_Link_Adapter –电缆连接图...........................................................275
38.Omron CS FINS – 功能存储器...........................................................................275
39.Omron CS FINS – 电缆连接图...........................................................................275
40.Omron 以太网 C 系列 – 功能存储器.............................................................276
41.Omron 以太网 CS 系列 – 功能存储器...........................................................276
42.Keyence系列 – 功能存储器...............................................................................277
43.Keyence系列 – 电缆连接图...............................................................................277
44.Keyence KV-700 – 功能存储器..........................................................................278
45.Keyence KV-700 – 电缆接线图..........................................................................279
46.Keyence KV-1000 – 功能存储器........................................................................279
47.Keyence KV-1000 – 电缆接线图........................................................................280
48.Matsushita NAIS-FP – 功能存储器 ....................................................................280
49.Matsushita NAIS-FP – 电缆连接图 .................................................................281
50.Generic 以太网/IP (AB ENET IP) – 功能存储器..............................................281
51.Sharp JW-20 JW-50/70/100-系列 – 功能存储器...............................................282
52.Sharp JW-20 JW-50/70/100-系列 – 电缆连接图...............................................283
53.Sharp JW-30-系列 – 功能存储器.......................................................................283
54.Sharp JW-30-系列 – 电缆连接图.......................................................................285
55.Siemens S7-200 PPI- 功能存储器.......................................................................285
56.Siemens S7-200 PPI - 电缆连接图......................................................................286
57.Siemens S7-300 MPI (PC Adapter)- 功能存储器...............................................286
58.Siemens S7-300 MPI (PC Adapter) - 电缆连接图..............................................287
59.Toshiba Prosec T-系列 – 功能存储器................................................................287
60.Toshiba Prosec V-系列 – 功能存储器...............................................................288
61.Toshiba Prosec T-系列/V-系列 – 电缆连接图 ..................................................288
62.JTEKT TOYOPUC PC2-系列 – 功能存储器....................................................288
63.JTEKT TOYOPUC PC2-系列 – 电缆连接图....................................................289
64.JTEKT TOYOPUC PC3-系列 – 功能存储器....................................................289
65.JTEKT TOYOPUC PC3-系列 – 电缆连接图....................................................293
66.Yaskawa CP-系列 – 功能存储器.......................................................................293
67.Yaskawa GL-系列 – 功能存储器.......................................................................293
68.Yaskawa MP-系列 – 功能存储器......................................................................294
69.Yaskawa CP-系列/GL系列/MP系列– 电缆连接图............................................294
70.Yokogawa FA-M3 – 功能存储器.....................................................................294
71.Yokogawa FA-M3 – 电缆连接图........................................................................295
72.RKC CB100 Modbus – 功能存储器 ...................................................................296
73.RKC CB100 Modbus – 电缆接线图 ...................................................................297
74.Yamatake SDC36/26 CPL – 功能存储器 ...........................................................297
75.Yamatake SDC36/26 CPL – 电缆接线图 ...........................................................299
76.通过另一台触摸屏与PLC连接............................................................................299  5
第三章 错误代码...............................................................................................................302
一.ViewJetCmore错误代码...............................................................................................302
二.PLC错误代码 ...............................................................................................................302
GMT+8, 2025-4-3 04:29
