[HMI/SCADA] Koyo光洋HMI软件 ViewJetCmore Version 2.75+SP10
山海致远 发表于 2018-12-20 15:05:22 | 显示全部楼层 |阅读模式
支持windows 7操作系统,对windows10兼容性未知。可以运行在虚拟机里安装windows 7进行测试。
安装文件下载:
在安装中会提示输入安装密码,这个不用理会直接跳过继续下一步安装即可。不影响使用,没有任何功能限制。
Welcome to ViewJetCmore Programming Software
Version 2.75 (24 Feb 2012)
1.Welcome
2.What's New
3.Known Problems and Conditions
4.Uninstallation of ViewJetCmore Programming Software.
5.Contact Technical Support
[Welcome]
KOYO ELECTRONICS INDUSTRIES CO., LTD would like to welcome you to ViewJetCmore Programming Software.
We at ViewJetCmore aim at offering users the best Operater Interface software and hardware in the world.
For a detail information to ViewJetCmore, please to see Help file:
You may use the ViewJetCmore Help file by selecting Start Menu>FactoryPortal>ViewJetCmore>ViewJetCmoreHelp from the Start menu.
[What's New]
10/17/2005 - Original Release ViewJetCmore Programming Software Version. 1.0
11/22/2005 - Version 1.1.1.3
    1)Function Improvement:Change of the system screen call method(Press the upper left corner for 3seconds)
    2)Function added:The restored alaarm is clear automatically(Panel Manager)
    3)Function added:Date Display(Alarm Message)
    4)Function Improvement:Screen Saver ON/OFF(PLC<->;Panel)
    5)Function added:Notification Option(Key Button)
    6)Function Improvement:Selected Object is marked. (Numeric Entry)
    7)Function added:Object Back Color(Lookup Text)
    8)Function added:Interlock
      Support Object
      8)-1.PushButton
      8)-2.Switch
      8)-3.RadioButton
      8)-4.IndicatorButton
      8)-5.StepSwitch
      8)-6.Try-StateSwitch
      8)-7.NumericEntry
      8)-8.Increment/DecrementValue
      8)-9.Thumbwhee
      8)-10.Slider
      8)-11.BitmapButton
      8)-12.Recipe
      8)-13.TextEntry
      8)-14.ScreenChangePushButton
      8)-15.ScreenSelector
      8)-16.Increment/DecrementHour
      8)-17.ActiveScreenSaver
      8)-18.AdjustDisplay
      8)-19.SetLanguage
      8)-20.VolumeControl
11/29/2005 - Version 1.1.1.4
    1)Function added:Display Progress Bar(Recipe)
12/07/2005 - Version 1.1.1.5
    1)Bug Fix:Can not select read/write bit device. when Koyo Modbus selected.
    2)Bug Fix:Alarm Message.
      Histry data chang to latest time stamp, When screen change by other error occurredor operate.
    3)Bug Fix:Numeric Entry.Tenkey display part shows Tag data.It must be show Zero value.
12/08/2005 - Version 1.1.1.5+1
    1)Bug Fix:Discrete address miss read when selected Koyo Modbus(S Operand)
    2)Bug Fix:Alarm No shifts diaplay after 2 digit(after No10)
12/11/2005 - Version 1.1.1.6
    1)Function changed:Notification Option(Key Button)
      The writing of Tag is changed into 100second ON from a set
    2)Touch buzzer sound is changed into a one shot(50ms) from during touch on
    3)Alarm Message
      3)-1.character size can be select
      3)-2.Added:Display Option
      3)-3.Added:Alarm Status
    4)Screen Saver status added(Panel->;PLC乯
    5)The present value displayed on a ten key.(NumericEntry)
12/13/2005 - Version 1.1.1.7
    1)Function Improvement:Embedded Data does not show when select Alarm Count(Alarm Message)
    2)Function Improvement:The alarm under occurring is not clear. (Alarm History)
12/17/2005 - Version 1.1.1.8
    1)Function added:Visibility(Key Button)
    2)Function changed:
      Bit device(X,GX,SP) which do not support bit write function by DirectLogic Modbus(Koyo Addressing).
    3)Function Improvement:
      When check off select all screens, all of screen check mark change to off.(ExportScreen images)
    4)Bug Fix:Data type of Tag cannot change. this bug fixed.
      But It support case of The tag does not using by other object.
    5)Function Improvement:Complete message shows when finished project transfer to External Memory Device.
02/10/2006 - Version 1.2.0.0
    1)National language support
    2)Line Trend Graph - New Logging & Resuming features.
    3)PID Faceplate Trend - New Logging & Resuming.
    4)Bitmap Text - Support for other Language Scripts.
    5)Import/Export CSV files -Tag Name Database & Address Book
03/28/2006 - Version 1.21.6.11
    1)Protocol added:Mitsubishi Q series CPU port connecting directly.
04/26/2006 - Version 1.21.6.17
    1)Protocol added:JTEKT PC3-Series.(Beta)
10/24/2006 - Version 1.21.6.39
   1)Mitsubishi Q series CPU port directly connected protocol all address access function addition
   CPU name: Q02, Q02H, Q06H, Q12H, and Q25H
   2)Keyence KV700/KV1000 protocol addition (Host-Link Protocol)
   It connects with link unit L20 and L20R and it has confirmed it.
   3)RKC Temperature CB100 RKC protocol/Modbus protocol addition
   4)Yamatake Temperature SDC-26/36 CPL protocol/Modbus protocol addition(As a 兝 version. )
   5)TOYOPUC PC2 protocol (Serial) correction
   丂Trouble to which only the WORD access can be done is corrected.
     It corresponds to the DISCRETE access.
   6)TOYOPUC PC3 protocol (Serial) correction
   7)TOYOPUC PC2 protocol (Ethernet) addition
   8)TOYOPUC PC3 protocol (Ethernet) addition
   9)The ladder tool function (Call Ladder parts) is added.
   The add-on software is separately necessary to use it.
   10)The print function (Print parts) is added.
ackaleji 发表于 2020-1-9 10:02:12 | 显示全部楼层
美国购买的这款屏幕也能适用吗?
GMT+8, 2025-4-4 00:19
