[PLC编程] Koyo PLC Programming Software V1.6.6.9 安装文件下载 光洋KPP PLC编程
山海致远 发表于 2018-12-20 10:43:19 | 显示全部楼层 |阅读模式
光洋PLC编程软件
OS Support:Windows XP 32bit,Windows 7/8/8.1/10 32/64bit
V1.6.6.9版本已由更新的V1.6.9.0版本替代
Koyo PLC Programming Software V1.6.9.0 安装文件下载 光洋KPP PLC编程
https://www.eleok.com/thread-124146-1-1.html
[1.6.6.9 - 2020/01/08]
1. Create Backup file if project file has to be upgraded.
[1.6.6.8 - 2020/01/03]
1. Enabled Convert Options for NK PLC
2. Create Backup file if project file has to be upgraded
3. Set IP Address in Link Name
4. Display Modbus Addressing in Device Comment Editor for NK PLC
[1.6.6.7 - 2019/12/24]
1. For NK1-PLC, Increased the limit of MAX CLBL and CAL from 64 to 256
[1.6.6.6 - 2019/12/19]
1. For NK0-PLC, PLC name and Series name changed.
[1.6.6.5 - 2019/12/13]
1. For NK PLC on Write program, system parameter check is added.
2. For NK PLC on Read program, system parameter check and read comment check is added.
3. PLC type check is added to avoid displaying Online/Offline difference.
[1.6.6.4 - 2019/12/04]
1. Changes are made in EPRINT instruction.
[1.6.6.3 - 2019/11/28]
1. Changes are made in EPRINT, EOPEN, ECLOSE instructions.
2. Comm Port Setup Port-3 ASCII Comm settings are updated.
[1.6.6.2 - 2019/11/15]
[1.6.6.1 - 2019/10/09]
1. Changed the default time out 10ms -> 200ms for
   NK1-PLC and NK0-PLC for instruction MRX and MWX.
[1.6.6.0 - 2019/09/26]
1. Added support of PLC NK0.
2. RTS Delay Settings for NK1 PLC is added for Port0 and Port2.
[1.6.5.1 - 2019/09/26]
1. Monitor Mode Option was not visible in Offline.
2. Gateway mode bug fixed.
3. Default retentive range for R-memory is corrected for SJ-Ether.
4. Comm Port default setup for PLC-454 and SJ-Ether is fixed.
[1.6.5.0 - 2019/08/23]
1. PLC Connection issue is fixed.
2. MRX/MWX and EWX/ERX R Memory display range extended.
3. PLC Setup Display issue at zoom 125% and 150% is fixed.
4. PLC Program name bug fixed.
[1.6.4.9 - 2019/07/26]
1. Monitor Mode option was visible in not supported version also.
2. MRX/MWX Number of Elements range is fixed for 03,04,16 code for NK PLC.
3. Allinputdlg operand range fixed for LD_LDGE instruction.
4. Data View new text value was getting change on open and close.
5. ModBus Slave Start Address selection issue is fixed.
[1.6.4.8 - 2019/07/16]
1. Bug fixes for Monitor Mode for SJ-Ether PLC.
[1.6.4.7 - 2019/07/15]
1. Comment Block in KAD file is removed for NK PLC.
2. Updated help files.
[1.6.4.6 - 2019/07/09]
1. Added following instruction support for SJ-Ether PLC
   EPRINT,EOPEN,ECLOSE for version > 4.0
2. Added following instruction support for NK PLC
   MULC,DIVC for version > 20190701
3. Added Monitor Mode for SJ-Ether PLC for version > 2.6
[1.6.4.5 - 2019/06/05]
1. Added following instruction support for NK PLC
   DLDEQ,DLDNEQ,DANDEQ,DANDNEQ,DOREQ,DORNEQ,
   DLDGE,DLDNGE,DANDGE,DANDNGE,DORGE,DORNGE,
   BMULD,BDIVD,MATHBCDD,MATHBIND,CRCXOR.
[1.6.4.4 - 2019/05/30]
1. On PLC connect - Comment comparison is made independent of program comparison.
2. NK1 simulator is updated for SETBIT and RSTBIT for K memory type.
[1.6.4.3 - 2019/05/17]
1. Changes are made for builtin CPU settings for SJ-12.
2. Japanese Help file Updated.
[1.6.4.2 - 2019/04/18]
1. Updated help files in English and Japanese.
[1.6.4.1 - 2019/04/11]
1. D2-265-1 Modbus Address bug fixed.
2. Connecting to D4-450 password locked state bug fixed.
[1.6.4.0 - 2019/03/25]
Version Updated to 1.6.4.0
[1.6.3.26 - 2019/03/13]
1. Fixed Non-Sequence Setting Display and Validation.
[1.6.3.25 - 2019/03/08]
1. PZ3 - Comm Port Setup for Non-Sequence , RTS Off Delay Disabled as DS and also PLCDB Updated
2. Added Comment Block in KAD file for all PLCs but Comment Block will be written only in supported PLCs
3. D4-454 Comm Port Setup Display issue in Non-Sequence Protocol
4. Allowed Writing of D2-260-1 KAD file to D2-263-1.
5. NK1 PLC - Program was read even pressing cancel on OnLine/Offline Difference Dialog.
6. Help File Updated for D2-263-1
[1.6.3.24 - 2019/02/28]
1. NK port 3 SMTP bug fixed.
2. Comment writing for languages bug fixed.
[1.6.3.23 - 2019/02/26]
1. Comm Port Setup for Non-Sequence Protocol
2. SJ-Ether Gateway mode bug fixed.
3. Added support for D2-263-1.
4. KEW sheet bug #389: Device replace issue for bit memory (B and PB).
5. Updated PLCDB for ECOM and ANLG instructions for Base and Slot numbers.
[1.6.3.22 - 2019/02/15]
1. SJ-Ether Gateway mode bug fixes.
[1.6.3.21 - 2019/02/14]
1. Device Selector bug fixes.
2. SJ-Ether Gateway mode bug fixes.
3. Updated Shortcut Keys Help list.
4. Updated Help file in Japanese.
5. Comment button in Stage View fixed.
[1.6.3.20 - 2019/02/07]
1. For HSCNT - Direction Relay, restrict I0-I5.
3. Add SJ Maintenance Tool in installer
4. Updated Help files in English and Japanese.
[1.6.3.19 - 2019/02/04]
1. Fixed the bugs of Modbus Addressing in Device-selection/Comment dialog.
2. Fixed DeviceNet Tool.
[1.6.3.18 - 2019/02/01]
1. Added Modbus Addressing in Device-selection/Comment dialog.
2. KEW Bug #387: Locked he PLC in case of error
3. KEW Bug #388: NK1 PLC Memory Map
4. Hide Gateway Mode Controls for NK1 and SN PLC
5. Updated Help files for gateway mode in English and Japanese.
6. Updated SJ Maintenance Tool.
7. Updated DeviceNet Tool.
[1.6.3.17 - 2018/12/25]
2. Updated Help files for gateway mode in English and Japanese.
[1.6.3.16 - 2018/12/24]
2. Device Information for R7677 in SJ-Ether.csv updated.
[1.6.3.15 - 2018/12/20]
[1.6.3.14 - 2018/12/18]
[1.6.3.13 - 2018/12/11]
[1.6.3.12 - 2018/12/10]
[1.6.3.11 - 2018/12/06]
1. Fixed problem of KPP freeze if one instance is connecting D2-265 and other one is SJ-Ether.
2. Updated OPC server for the same.
3. Added SJ-Ether gateway help in English(S and DL mode).
[1.6.3.10 - 2018/11/30]
[1.6.3.9 - 2018/11/28]
1.  SJ-Ether Gateway mode bug Fixes.
2. Added new japanese help.
3. Open Gateway help from com settings help button if gateway mode is selected.
[1.6.3.8 - 2018/11/21]
1. Default com port settings of PLC's other than SJ-Ether was incorrect.
2. SJ-Ether Gateway mode bug Fixes.
3. Erasing background of property pages for PLC Setup to look similiar as dialogs.
[1.6.3.7 - 2018/11/14]
1. Allow Parameter file(0x08) R/W that is Com port Gateway settings in SJ-Ether PLCs having FW version greater than V2.40.
2. KEW Bug #386: Incorrect formating of Signed decimal values for 16 bit.
3. "File is corrupt" issue in file saving fixed.
[1.6.3.6 - 2018/11/05]
1. Added SJ Maintenance tool in Tools menu for SJ-Ether PLC.
2. Align Buttons in com port setting for SJ-ETH.
[1.6.3.5 - 2018/10/30]
1. SJ-Ether Com Gateway Bug Fixes.
2. Instruction window description crashes in case of MATHBIN whose description contains shift operators.
[1.6.3.4 - 2018/10/24]
[1.6.3.3 - 2018/10/23]
SJ-Ether com port Gateway mode bug Fixes.
[1.6.3.2 - 2018/10/12]
1. System parameter initialization fails for 05 PLC as read fails just after init SPD memory.
2. Updated default retentive ranges for PLC whose values are different from system parameter initialization.
3. Added functionality to merge column header in GridCtrl.
4. Updated Range of V memory For ERX/EWX/MRX/MWX (added 50000-77777)
5. Added New SJ-Ether Master Extension feature
        1. SJ-Ether com settings updated for new firmware PLCs.(maintaining a flag to enable/disable this feature)
        2. Added new classes for modbus address dialog.
        3. SJE master extension in Project read/write too.
        4. Gray-out port 1 normal mode settings.
6. Added Help Button in PLC setup property pages.
[1.6.3.1 - 2018/08/30]
KEW Bug#385: Can not read the program from NK1 in ON-LINE mode.
[1.6.3.0 - 2018/07/26]
1. Setting value for Xon/off and RTS control from PLC for D4-454.
[1.6.2.11 - 2018/07/05]
1. During import of KAD file with password, it is not reconnecting.
2. If kad file program size > PLC program size, after writing, the rest of old program remains -> Clear PLC memory before writing.
3. Fixed KPP crash in case of write All with no password block set.
4. If PLC password is not same as KAD password, Can not write kad file.
[1.6.2.10 - 2018/07/03]
1. KEW Request: Enable Config block for password in DL-260-1 PLC for .kad File import/export.
2. Fix crash issue of .kad file export in offline state.
[1.6.2.9 - 2018/06/27]
1. KEJ Bug: In Modbus Mapping, Validate Modbus address on function code change along with Hex and Koyo addresses.
2. KEIN Internal: In Ether Module list
        1. Updated timeout to 5000 from 1000 ms.
        2. Edit KOP devices updated in case of multiple adapters.
        3. Disable selection of blank row of active devices on Ethernet.
3. Added .kad File export and writing in PLC 260-1 for password locked state.
[1.6.2.8 - 2018/06/21]
1. KE Bug: For Inst MT_ORG( SJ-Ether PLC) Cross reference was showing memory types for hidden operands.
2. KE Bug: KPP Crash by PID in password lock state.
3. For Modbus Mapping Table for ERX/MRX/MWX/EWX
        1. Display Alias in Table for V-Memory if alias is enabled.
        2. Display one column and edit box for Hex value of Modbus addresses.
        3. Enable editing of Koyo address.
        4. Adding Buttons for selected memory types in table dialog for easier selection.
[1.6.2.7 - 2018/06/12]
1. KE Request: 'Write all' failed because address is being read by PLC DB instead of generic blocks.
2. KE Request: Change String of RTS ON check in case of modes 72,73 for PLC 260, 263, 263
3. KE Bug: In case of PLC SU-6M, writing project in run mode fails due to IO data legacy block.
4. KEJ Request: Updated min value of watchdog timer to 0->2 ms.
5. KEW Request: For PLC D2-260-1, allow connection and project writing in password locked state.
[1.6.2.6 - 2018/05/22]
1. KEW Bug#384: In the stage View, ATMR, AHTMR, UDCNT monitor error display.
2. Split Data register range from 400-777 to 400-677 and added new system variable 700-777 for PLC D2-263.
3. Updated respective indexes in instructions and below tables for PLC D2-263.
4. KEJ bug: Com port settings of SJ-Ether written by 'Write all' are lost on PLC Reboot.
5. Disable writing of system parameters during Run Mode by write all or write project to PLC for SJ-Ether.
[1.6.2.5 - 2018/05/18]
KE Bug #19: Port 2 Settings were not writing correctly in PLC from Config blocks.
KE bug#20: Online offline difference is not coming for different models of SJ-Ether on connect having difference in Com port Config block.
KE reported bug: When KPP is connected and system goes in sleep, the connection is corrupted and system is needed to restart for connecting again
[1.6.2.4 - 2018/05/18]
1.Updated strings for KPP Improvement#41
2.PLC lock itself after single wrong entry for PLC D2-263/D2-261/Sj-Ether/D2-265.(Should allow atleast 3 trials)
[1.6.2.3 - 2018/05/16]
1. KEW Report#378 : On text file import, the status bar was getting hidden.
2. KEW Bug#381: On Clear password in offline state KPP Crash.
3. KE Improvement#40: Updated default data type as Hex in Device Editor Dialog.
4. KPP Improvement#41: Added Com port settings for PLC SJ-Ether in Project and Enabling offline set up of com port.
5. KE request: For PLC D2-263 Disable pointer range from  P41240`P577777.
[1.6.2.2 - 2018/05/14]
2. KEW Bug #379 NK1 motion instruction helps jump to SJ-ETH's motion instruction help or blank page.
3. KEW Report#380 : For NK1 PLC, the Comment difference to be shown for rung and device comments.
4. KEW Bug #381 : For NK1 series PLC, PLC settings -> password -> write KPP, causing KPP crash fixed.
5. KE request: For PLC 263 setting of default values for retentive showing error.
6. KE Request: Added Modbus-PLC mapping table for instruction ERX/EWX/MRX/MWX.
7. KEJ reported bug: Opening project file shown file corrupted when blank rung comment was written in the project file.
8. For PLC's D2-262, D2-263 ->Restricted writing in Run Mode and shown dialog same as System Init to stop PLC.
9. KE Request: Updated NK1 Sub-CPU IDs and disable motion instructions for xxxDR CPUs.
10. KE Request  D2-263 program size increses from 20 K-> 23.5 K.
11. KPP data view can not edit R41240`R41777 for D2-263 as SP range is set as non-editable and max range is set as of NK1.
12. KE Request: Updated English and Japanese help files.
[1.6.2.1 - 2018/04/26]
1. Fixed KPP crash while entering Japanese characters to instruction input dialog.
[1.6.2.0 - 2018/04/20]
1. Added Korean Language Support
[1.6.1.6 - 2018/04/18]
1.For PLC D2-262 I/O Diagnostics not showing error in bases other than 0 fixed.
2.Updated stdplcdll.dll.
3.Updated PLC Simulator.
[1.6.1.5 - 2018/04/12]
1.  PLC Port changes for D2-262, D2-263
    1. Hide mode 71, 72, 73 for 262,263
    2. if wiring set up is 485, String change for RTS ON in check and uncheck state.
2. GLBL is executed only while the above stage is running. Therefore it is better to be connected.
3. KPP Improvement List #23 : To make connection test faster , decrease timeout in linksetup dialog
[1.6.1.4 - 2018/04/06]
1. D4-454 Bugs:
Updated string for FW update Mode change dialog.
Reverse the values for Txm start and end code in Non-sequence mode for 454 PLC.
2. For PLC D2-262 I/O Diagnostics not showing error in bases other than 0.
3. KEW Request to enabled RCMPR and RCMPRC instructions for SN PLC same as DS
4. KEW#377: On Find for WORD Instructions(E.g. SET and RST), for bit memories(e.g. M, C, T, Q, I etc.), find was showing Q0 as a match while searching for any Q memory (e.g. Q10/Q120 etc.).
5. KEW#376: On KPP Package file write on to the PLC, package file program was shown appended in the KPP views
6. Monitoring of MT_ABSC, MT_INCC, and MT_PWM instructions in stage view.
7. Displayed string in MT_ORG instruction during monitoring (ON) in stage view.
[1.6.1.3 - 2018/03/27]
1. Treated PLC PAUSE mode as RUN mode while writing program.
2. Updated Ladder and Stage Draw for MT_LTAB Instruction monitoring mode.
3. Checked PLC switch position before writing parameters.
4. Fixed PLC mode change issue after Write All.
5. Changed PLC Setup menu options while simulating(unchanged for NK PLCs).
6. Added compare of Device comment, Rung comment and stage comment in KPP vs PLC on PLC Connect.
7. String correction for MT_TAB and MT_LTAB instruction.
8. Updated instruction icons for instructions MT_LINE and MT_LTAB.
9. Help file updated.
10. Updated PLC Simulator DLL.
[1.6.1.2 - 2018/02/27]
1. In stage instruction draw, for blank operands, skipped caption draw. e.g. MT_ORG for Mode K5
2. For SJ-Ether PLCs, while writing interrupt setups, restricted writing in Run Mode.
[1.6.1.1 - 2018/02/26]
1. For INSTN_MT_ORG_N Instn's for Mode K5 removed Search Direction Parameter.
2. For SJ-Ether PLCs, while writing S-10D, Analog Module setups and BuiltInCPU parameters, restricted writing System parameters in Run Mode.
3. For few motion instructions, while monitoring, monitoring text background color was set but text color was not set.
[1.6.1.0 - 2018/02/23]
1. For MT_ORG Instn's Search Direction parameter, displayed Clockwise/Counterclockwise instead of K0 and K1.
2. For SJ-Ether PLCs, restricted writing System parameters in Run Mode.
[1.6.0.3 - 2018/02/20]
1. Updated Status Monitor for all HS/Motion instructions in both ladder and stage view
2. Added support for Simulator for 05/06/250-1/260/260-1/262/263/265/SJ-Ether
[1.6.0.2 - 2018/02/19]
1. Stage view for all HS/Motion Instructions.
2. Added Status Monitor for all HS/Motion instructions in both ladder and stage view
3. Disable Non Sequence modes 0x71, 0x72, 0x73 for D2-262,263 and according to wiring set up setting
4. Added Updated Japanese Help for HS/Motion instructions
5. MT_TAB Instruction Layout improved and saved temporary grid data for editing
[1.6.0.1 - 2018/01/23]
1. Updated instruction draw for MT_AXIS and MT_ORG instructions.
[1.6.0.0 - 2018/01/19]
1. Text file import was not importing rung comments.
[1.5.0.17 - 2018/01/18]
1. Fixed KPP crash on text file import.
[1.5.0.16 - 2018/01/17]
1. X-Ref Data for MT_LTAB and MT_TAB corrected
2. LTAB Byte code Decode Format corrected
3. Axis Number validation for MT_LTAB not required
4. Address Validation added for MT_TAB Instruction
5. Removed MT_SYNC and MT_CAM instruction in SJ_Ether PLC
6. SJ-Ether FW Update File Step1/Step2 Restriction
7. Added 262 PLC support in 02-PM Tool
[1.5.0.15 - 2018/01/16]
1. MT_TAB Instruction X-Ref Data was not being set for more than 1 step number
2  For MT_INCC and MT_ABSC, Ladder View Displayed String corrected for Japanese langauge.
3. Corrected displayed height for High Speed Counter and Motion instruction in Ladder View.
[1.5.0.14 - 2018/01/15]
1. Disabled 300,600,1200 Baudrate for 262 and 263 PLC.
2. Mnemonic Compiler issue with new motion instructions
3. MT_LTAB Instruction, addressing changed
4. MT_INTC, For I0-I3/7, keep NO NC enable, otherwise disable with NO
5. Set new style progress for 262 PLC
6. Read/Write comment not support message added in all languages.
7. Txt file Import/Export Issue in Device Comment and Program
[1.5.0.13 - 2018/01/11]
1. HSDRM and HSTAB Instruction Japanese Description corrected
2. Tab Order corrected in HS Instructions
3. Version Details Display made litte wide
4. To allow D2-263 PLC to connect to D2-DCM via Modbus, added comment read/write auto enabled/disabled function
5. Added Support of D2-263 in D2-02PM Tool
6. FW Update File Validation corrected for D2-262 and D2-263
[1.5.0.12 - 2018/01/10]
1. PLC Memory Table Updated for D2-263 and D2-265 PLC
2. Communication disconnect issue after long wait at message prompt to clear the display program
3. Export Program (Txt) Issue when exporting with address range
4. Export Program Dialog Chinese String cut
5. HSDRM Dialog Horizontal Scroll removed
6. IBOX Instruction Help index was shifted due to addition of HS and Motion Instructions.
7. Find Device in Double Word Instruction
8. Help File Updated for Screen Size Requirement
[1.5.0.11 - 2018/01/09]
1. Device Validation issues in MT_VCHG
2. PLC Run Mode Write message string updated for SJ-ETH
3. KPP Crash issue in FW Update in offline mode
[1.5.0.10 - 2018/01/08]
1. Device Validation issues in MT_AXIS and MT_CAM
2. TMR does not work in RUN mode, NK1-Simulator(PLC DLL Updated).
3. Version Details added in Help Dialog
[1.5.0.9 - 2017/12/28]
1. Invoking AEX help from INT instruction on F1 Click
2. Few changes for CPU D2-263
3. Fixed Rung comment read from PLC for SJ-Ether
[1.5.0.8 - 2017/12/26]
1. Fixed the crash during import of Rung Comment.
2. SP0 does not work in RUN mode, NK1-Simulator.
3. System TagNames were cleared in case TagNames read from PLC have zero size.
4. Bug fix for Motion and HSCNT instruction.
5. Firmware Update menu added for D2-263
6. Help files Updated for TMRF Instruction
[V1.5.0.7 - 2017/12/15]
1. Addition of High Speed Counter and Motion Instructions
2. Fixed the issue of compilation on '/' press with LD instruction.
3. Fixed the issue with H2-ERM PLC image.
4. Made changes to Separate status from PID monitor Ramp/Soak dialog.
5. Changed project path in options to the last saved project path.
6. Made changes to persist display order of page monitor dialog.
[V1.5.0.6 - 2017/12/08]
1. Import Rung comments not working
[V1.5.0.5 - 2017/12/01]
1. Port2 PLC Station Number setup for Modbus
2. D2-260-1 Program Max Size set to 20480 in online
3. Tools Updated in installer.
[V1.5.0.4 - 2017/11/18]
1. Updated System Info (PLC Name and Memory Size) for D2-260-1
2. Format Floats to show 6 digits in numbers same as DS
3. For SN PLC, few extra controls were visible on COM Setting dialog
4. Added entry of NK1H-CPU20 entry in KPP-2.ini
[V1.5.0.3 - 2017/11/15]
1. Added D2-260-1
2. Opening the KPP file created by V1.1.039( or before) in V1.1.0.44(or later), the IBOX instruction will be the other inst.(NK1)
3. Image Display for SN-PLC PLC in System-Config.
[V1.5.0.0 - 2017/10/01]
1. Added support for SJ-Ether PLC
GMT+8, 2026-10-1 00:30
