TWIDOSOFT VERSION 3.5下载
山海致远 发表于 2018-11-16 14:51:21 | 显示全部楼层 |阅读模式
下载链接:
Windows 98 Second Edition, Windows 2000 or Windows XP
- RS232 with a DB9 connector,
- USB port, if the PC-compatible computer is under Windows 2000 or Windows XP, and then the TSX PCX 3030 cable,
- BlueTooth connection through the VW3A8114 dongle on the Twido controller, and through the BlueTooth key on the PC if it isn't BlueTooth inside.
- Ethernet using the port 3 of the new Twido controller TWDLCAE40DRF, or using the Ethernet enabler TwidoPort ref 499TWD01100.
- Modem: It's possible to use a modem connected to the PC-compatible computer. You must install the modem under the Windows operating system, and then select the modem by the sequence:  "File" menu, and then "preferences" of Twidosoft.
GMT+8, 2026-9-22 18:27
