WinCC Open Development Kit ODK V7.5下载
山海致远 发表于 2018-11-15 16:31:20 | 显示全部楼层 |阅读模式
下载地址
The functions of the current WinCC Open Development Kit ODK V7.5 option can be used within the WinCC OS environment.
Limitations
There are certain limitations when using some functions on the PCS 7 OS. More information on the functions affected can be found in the PCS 7 documentation.
Compatibility
The current ODK V7.5 version is based on WinCC V7.5.
Applications created in debug mode can only be executed if the corresponding debug DLLs are installed on the computer.
Picture Tree Manager renamed to Picture Tree
The "Picture Tree Manager" editor was revised for the version WinCC V7.5 and renamed "Picture Tree".
The ODK port was not hereby changed. The information of the online help for "ODK Picture Tree Manager" also applies to the new "Picture Tree" editor.
Restoring edited samples
If you want to restore individual files or complete samples after changes, you can copy these parts directly from the CD, from the "Samples" catalog.
ODK functions which are not available to certain users
The following ODK functions are not available for users with standard user rights of Windows:
CreateDatabase
DatabaseAttach
DatabaseDetach
yishe133 发表于 2023-6-9 16:20:19 | 显示全部楼层
楼主,下载链接还能用吗?
 楼主| 山海致远 发表于 2023-6-9 16:32:38 | 显示全部楼层
楼主,下载链接还能用吗?
可以的
yishe133 发表于 2023-6-9 17:08:32 | 显示全部楼层
已下载,感谢!!!
有7.5 sp2 版就更好了
xfkklove 发表于 2023-9-27 13:26:33 | 显示全部楼层
链接还能用吗现在?
 楼主| 山海致远 发表于 2023-9-28 11:33:29 | 显示全部楼层
链接还能用吗现在?
链接有效的,假如万一失效了可以回帖告知,然后更新。
GMT+8, 2025-4-21 09:49
