FANUC ROBOGUIDE V8.3 (Rev.I)下载
山海致远 发表于 2018-10-18 19:31:23 | 显示全部楼层 |阅读模式
下载地址链接
https://www.eleok.com/thread-123547-1-1.html
1. What's new in Rev.I:
        * Support for V8.30p01, V8.20p16, V8.13p13, V8.10p23, V7.70p44, V7.50p27
          virtual robots.
        * Support for new robot models:
                - M-1iA/1HL
                - M-10iA/12S
                - M-10iA/7L
                - M-20iA/12L
                - R-2000iC/125L
2. System Requirements(此版本软件不支持win10及更新的操作系统,请确认符合以下操作系统要求)
                                        Recommended Minimum
        Operating System        Windows Vista SP2 (32-bit and 64-bit)
                                Windows 7 (32-bit and 64-bit)
                                Windows 8/8.1 (32-bit and 64-bit)*
                                Windows 7 64-bit recommended.
        System Memory                1 GB; 4GB recommended.
        Video Card:
          RAM                        512MB
        Free Hard disk space        1GB
        OS Requirements                Administrator Privileges to install product and
                                Normal font size (96DPI).
                                Internet Explorer 6. Internet Explorer 8 or later
                                recommended.
                                Version of Internet Explorer and OS in which
                                the vision setup operation test was done is
                                different in each robot software version.
                                Please refer to [Vision Simulation/Restrictions]
                                section of ROBOGUIDE online munual for detail.
                                Windows RT is not supported.
                                Screen should be 96DPI.
                                You cannot use Guest acount for ROBOGUIDE.
                                *Touch panel operation on Windows 8 is not supported.
asjeanreno 发表于 2018-11-3 15:19:36 | 显示全部楼层
都有仿真软件呀,厉害。
i525354 发表于 2019-8-20 23:37:22 | 显示全部楼层
需要,我的教材书就是8.3,正合适,收了
GMT+8, 2025-4-19 15:59
