FANUC ROBOGUIDE V8下载
山海致远 发表于 2018-3-25 16:25:14 | 显示全部楼层 |阅读模式
下载地址
https://www.eleok.com/thread-121688-1-1.html
 楼主| 山海致远 发表于 2018-3-25 16:31:00 | 显示全部楼层
(*) R-30iB virtual robot is supported.
    Please select correct version of virtual robot.
    (R-30iA virtual robot is currently more stable.)
- How to Install Options
  You can install the following options.
        Line Tracking Option            LineTrackingPCOption\setup.exe
        CoordWeldPRO                    CoordWeldPRO\setup.exe
        Vision Option                   VisionPCOption\setup.exe
        Duty Estimation Option          DutyEstimationPCOption\setup.exe
        Unified Interface Option        TUIPCOption\setup.exe
        Reducer Life Estimation         LifeEstimationPCOption\setup.exe
        PowerEstimation                 PowerConsumptionEstimationPCOption
Contents of this ReadMe file:
        1. What's new in Rev.A
        2. System Requirements
        3. Pre-Installation Notes
        4. ROBOGUIDE Features
        5. Supported Virtual Robot Controllers
        6. Supported Robot Models
        7. Known Issues
        8. Reporting ROBOGUIDE Issues
1. What's new in Rev.A:
Supported R-30iB robot controller. Supported new iPendant.
Robot operation new features
        Supported collision avoidance function.
        Supported power on/off virtual robots.
        Supported integrated PMC simulation function.
        Supported showing SpaceCheck zones.
        Supported creating a virtual robot from image backup files.
Simulation new features
        Improved high-accurate servo gun simulation function.
        Supported regenerative power simulation function.
        Supported robot tool trace function during simulation.
        Supported enabling/disabling set view point instruction.
CAD loading new features
        Supported importing COLLADA format.
        Supported importing and exporting Wavefront OBJ format.
User interface improvement
        Supported I/O Interconnects setting that can set the number of I/O arbitrarily.
        Improved target group edit form.
        Added cold start button on virtual teach pendant.
        Simulation program editor supported joint representation of taught position.
3D graphic improvement
        Improved performance of graphic drawing and collision detection.
        Supported changing tool color.
        Supported gradient background color.
        Supported changing compass color.
        Supported AVI recording with true color.
        Supported selecting codec for AVI recording.
Vision improvement
        Supported selecting iRVision Enable/Disable mode.
        Supported multiple robot visual tracking simulation.
        Supported the function setting the standoff of 3D laser vision sensor to 400mm or 600mm.
        Supported display view area function for 3D laser vision sensor.
MotionPRO
        Supported reducer life optimization for learning robot
WeldPRO
        Supported multi-texturing function for rectangular-box shapes.
PaintPRO
        Ability to add macro calls for wait/release in a PaintPRO job
        New calibration procedure
                                        Recommended Minimum
        Operating System        Windows XP Professional SP2 (32 and 64 bit)
                                Windows Vista SP2 (32 and 64 bit)
                                Windows 7 (32 and 64 bit)
        Processor Type                AMD Athlon 64 3200+ or Pentium IV 2.4 Ghz
        System Memory                1 GB
        Video Card:
          RAM                        512MB
          Color Depth                24-bit color?
        Free Hard disk space        1GB
        Additional Hardware:        Ethernet, DVD 32x
        OS Requirements                Administrator Privileges
                                to install product and
                                register full version of software
        Full Administrator Privileges
        FANUC uses InstallShield?technology which requires the software installer
        to have full administrator privileges on the machine where the software is
        being installed.?Please contact your Information Systems Department
        for assistance if you do not have full administrator privileges or are
        unsure if you have full administrator privileges.
        Using ROBOGUIDE with an Internet Firewall
        Most PC systems make use of a firewall to prevent unauthorized
        internet users from accessing your private PC network. Windows
        XP SP-2 and Vista have built-in firewalls, or your PC may use a
        firewall provided by a 3rd party such as Symantec or McAfee.
        ROBOGUIDE uses a FANUC Robotics virtual robot which
        communicates with other programs via a network protocol.
        Therefore, some programs that ROBOGUIDE installs, must be
        added to the firewall in order for ROBOGUIDE to work properly.
        The ROBOGUIDE installation automatically adds these programs
        to the Windows XP  or Vista firewall. If your PC is using a third party firewall
        program, you must add these programs manually. You should contact
        your IT Administrator, or consult the 3rd party software documentation
        regarding allowing programs access to the firewall.
        The following programs must be allowed network access:
        C:\Program Files\FANUC\ROBOGUIDE\bin\RGCore.exe
        C:\Program Files\FANUC\Shared\Robot Server\frrobot.exe
        C:\Program Files\FANUC\Shared\Off Line\FRVRC\frvirtual.exe
        C:\Program Files\FANUC\Shared\Robot Server\frrobotneighborhood.exe
        "C:\Program Files\FANUC" is the default installation directory.
        Please use the path you specified if you changed the default setting.
        Workcell Compatibility
        New enhancements and capabilities are continually being added with
        each release of ROBOGUIDE and to support these changes its workcell
        data structure is changing, which makes the newer workcells incompatible
        with prior versions of ROBOGUIDE. Therefore, FANUC recommends you
        always make backups of existing workcells prior to installing any
        newer version of ROBOGUIDE.
?牋
        OpenGL Compatibility
        FANUC has identified problems with specific video cards. ROBOGUIDE
        uses OpenGL as the basis for graphics operations so depending on
        how well your video card supports OpenGL you may need to update
        its software driver or possible reduce or disable its hardware
        acceleration for proper operation of ROBOGUIDE AVI captures
        and in extreme cases for basic operations.?
        ROBOGUIDE Cycle Time Accuracy
        ROBOGUIDE reports accurate motion cycle time and
        cannot accurately predict cycle time results for programs
        containing instructions other than motion and wait instructions.
        Using ROBOGUIDE Vision Utility Plug-in
        If the Vision Utility Pug-in is installed, you must run the "VisCtrls.exe" installer
        located in the VisionPCControls folder on the installation disk.
         * A fully integrated environment with graphical UIF
           components to simplify the robot cell teaching process
         * Process Navigator.
         * Extensive workcell tutorials
         * Extensive Help for procedures of how to operate the software
         * Sample workcells
         * A full 3D world environment: with zooming, panning, and rotation.
         * Robot jogging: with an end of arm drag and drop teach tool
           and traditional teach pendant style jogging.
         * Single robot workcells: many robots supported
                - Work envelope view
         * Workcell Modeling: support:
                - IGES CAD import
                - Primitive shapes: spheres, rectangles, and cylinders
         * Workcell Library
                - CAD Library of basic CAD models
                - Ability to add your own images to the library
         * Create multi group and multi axis machines
                - Easily create machines that are driven by
                    robot controller motors.  Motors can be extended
                    axes or multi group defined controller configurations
         * Program Teaching
                - Create basic TPP Programs
                - Teach TPP positions by jogging the robot,
                   manual entry, or by clicking on objects in the cell
                - Supports automatic teaching of MH PICK and
                  PLACE positions
                - Motion statement, wait statement support
                - Single running program support.  Multiple
                  running program support later.
                - Open / Close Hand view setup
                - Open / Close Hand instructions that enable
                  animation of workcell pick and place applications.
         * Program generation from CAD:  find entities in CAD files
           and use these entities to automatically generate robot
           programs.  This capability can drastically reduce
           programming time
         * Support for UTOOLS
                - Attach tooling graphics to the robot for open
                  and close imaging
                - Define UTOOL values
         * Support for UFRAMES
                - Associate UFRAMES with workcell objects
                - Teach relative to UFRAMES.  Allows moving
                  of taught positions with parts / fixtures to check
                  reach.
                - Quickly change taught reference frame from
                  World coordinates to a UFRAME coordinate
                  system
         * Quick reach check functionality
         * Program execution: programs can be run within
           Roboguide and cycle time information can be generated.
                - Run, hold, abort programs
                - Alarm logs for program errors
                - Animation / simulation in the 3D CHUIWorld?
                - TP Profiler
                        - TP Line segment times
                        - TP Program times
                        - Actual TP Trace ?display of
                          actual robot motion vs. taught path
                        - TP Trace by speed, orientation,\
                          acceleration
                - Cycle time information is generated by FANUC
                  Virtual Robot and has accuracy of FANUC
                  Robotics RRS modules
                - Robot payload is automatically adjusted as
                  the program is executed and the part is picked
                  and placed
         * AVI Movie file creation
                - Create AVI抯 of your running workcell in
                  multiple screen resolutions
         * Integration of Virtual robot interfaces just like the robot.
                - Virtual Teach Pendant.  Allows you to program
                  just like a robot.
                - KCL window for accessing KCL commands
                - Web Server window
         * Full access to HandlingTool TPP instructions through
           the virtual TP.  Program robot programs just like the robot.
         * UFRAMES operate just like the real robot
         * Create Virtual Robot allows you to configure your
           virtual robot with robot options.
         * Support for simulation programs and .TP programs.
           Simulation programs use the Roboguide simple TP
           editor which allow you to quickly create simulation
           programs which animate the workcell.  TP Programs
           are fully functional robot programs that can be directly
           downloaded to a robot.
                - Simulation programs can be quickly
                  converted to TP Programs
         * Simple editor supports the Call instruction
         * Quickly move to points on a surface by holding the
           CTRL-SHIFT keys and clicking on a surface.
         * Full support for Calibration of your Roboguide
           workcell to the actual workcell.
        ROBOGUIDE supports the following Virtual Robot
        Controller (FRVRC) Platforms and Versions:
        * R-30iB Robots - V8.10
        * R-30iA Robots - V7.20, V7.30, V7.40, V7.50, V7.70
        * R-J3iB Robots - V6.30, V6.31, V6.33, V6.40
        * R-J3 Robots - V5.30
        * Robot models supported in this version of ROBOGUIDE are
          listed in the serialize wizard during robot creation.
7. Known Issues
      None
    Procedure for handling all PRO product issues
    Send an email to:
     * In North America:
           ROBOGUIDESupport@fanucrobotics.com
     * In Europe, send support issues to the appropriate country support email address:
     * Include the following information when reporting PRO product issues:
      1. Basic Information
          a. Customer Profile
               i. Name
               ii. Company
               iii. Position
               iv. Department
               v. Address
               vi. E-mail
               vii. Phone
               viii. Fax
          b. Computer Profile
               i. Hardware
                 1. Machine Type
                 2. Machine Speed
                 3. Hard disk size
                 4. Amount of RAM
                 5. Video Card Manufacture
                 6. Video Card Memory
              ii. Software
                 1. OS Type and Version
                 2. Service Packs installed
                 3. IE Version
          c. Roboguide usage details
               i. Version or PRO.  Please include which process plugin
         you have.  ie. PalletPRO
               ii. Revision of PRO.  Please include which process plugin
       2. Additional Details
           a. Other FANUC software installed on machine
           b. Roboguide Version and Revision
           c. Robot model being used
           d. Information on what their trying to simulate
           e. Copy of workcell directory, if possible
       3. Issue information
           a. Description of problem or concern
           b. What function were you trying to perform
           c. If possible, describe what you were doing before problem occurred
GMT+8, 2025-4-19 15:59
