Lexium Motion Control V01.07 CD2011 下载
山海致远 发表于 2018-2-22 11:32:24 | 显示全部楼层 |阅读模式
1.   Software’s :
Easy Motion
Motion Pro / CoDeSys programming, with SoftMotion library
2.   Start Applications
Basic Lexium Controller project:    LMC Template empty.pro
o   Lexium Controller target configured
o   Standard system library
o   No task configured
Motion Lexium Controller project :   LMC Template with LEX05 on MotionBus.pro
o   SoftMotion library
o   Motion Bus library
o   Configured Motion cycle task, at 2ms
o   Bus Interface with one LEX05 configured
Motion Lexium Controller project :   LMC Template with LEX23 on MotionBus.pro (New !)
Application template project:    Lexium Application Template.pro
o   Manual and automatic modes
o   Configuration modes
o   Error handling
o   Motion Task Editor
o   Configured Motion cycle task, at 5ms
o   Bus Interface with LEX23 configured
After installation, these files are located on (default path):
C:\Program Files\Schneider Electric\Motion Control\CoDeSys V2.3\Targets\Schneider Electric\Lexium Controller V0107\Examples\Templates
Libraries
o   SoftMotion package
o   New Softmotion library: Lexium23CANdrive.lib for Lexium 23 on CANmotion (New!)
o   New library: Lexium23ControllerBusinterface.lib for Lexium 23 on CANmotion (New!)
o   New library: LMC_NewLexium23SoftmotionProject.lib for Lexium 23 on CANmotion (New!)
o   Icla motion library for CANopen
o   ATV31 and ATV71 and ATV312 motion library for CANopen.
o   Lexium 32 motion library for CANopen
o   Lexium 05 and SD328 motion library for CANopen
o   Lexium 15 motion library for CANopen
o   Application Function Blocks:
•   Flying Shear
•   Rotary Knife
•   Clamping
•   Grouping / Ungrouping
Important information:
This CD version is the first official version compatible with Lexium 23 on CANmotion.
The usage of Lexium 23 on CANmotion requires the following specific libraries:
o   Lexium23CANdrive.lib
o   Lexium23ControllerBusinterface.lib
Lexium 23 cannot be mixed with other drive (Lexium 32, Lexium SD3…) on the same CANmotion.
To start a project with Lexium 23 on CANmotion please use the following programming example:
o   LMC Template with LEX23 on MotionBus.pro.
Configuration files for DeviceNet and Profibus
After installation these files are located on (default path):
C:\Program Files\Schneider Electric\Motion Control\CoDeSys V2.3\Targets\Schneider Electric\Shared Files\PLCConf
DeviceNet :
o   .eds file : LMC20A_E.eds
o   .ico file : LMC20A_E.ico
Profibus
o   gsd file : TELE0AAF.gsd
Starting the Registration Wizard
The Registration Wizard may be started:
•   For unauthorized software with a start count (each 10 Motion Pro / CoDeSys start), from the Splash screen that is displayed reminding you that the software should be authorized.
•   On demand, from a shortcut in the program group.
Default path :
C:\Program Files\Schneider Electric\Motion Control\Registration\Lexium Motion Control\
Lexium 控制器中文手册.pdf (475.76 KB, 售价: 10 E币)
Lexium_Motion_Control_V01.07_CD2011.rar:若需要可以回帖索取
GMT+8, 2025-4-20 11:13
