SIMATIC S7-200 to SIMATIC S71200 software conversion tool
山海致远 发表于 2016-3-27 00:37:31 | 显示全部楼层 |阅读模式
The following software must be installed on your computer or programming device:
● SIMATIC STEP 7-Micro/WIN V4.0 SP6 (or later)
● SIMATIC STEP 7 Basic V10.5 SP2
● SIMATIC S7-200 to SIMATIC S7-1200 software conversion tool
The STEP 7-Micro/WIN program that you want to convert must have these properties:
● The program must have been created using STEP 7-Micro/WIN V4.0 SP7 or an earlier version of STEP 7-Micro/WIN.
● The program must have been created using SIMATIC programming mode. IEC programming mode is not supported.
● The program must have been saved in LAD (ladder editor) format.
● The program must compile with no errors.
● All user-defined password block protection must have been removed from the STEP 7-Micro/WIN program. Remove the password protection from the main routine, subroutines, interrupt routines, and all data pages in the data block. Any program block that is password protected will not be converted.
下载地址 http://www.99res.com/archives/308820.html
GMT+8, 2026-3-13 16:49
