Proworx32 V2.1 SP2下载
山海致远 发表于 2016-2-2 16:31:58 | 显示全部楼层 |阅读模式
Programming software for Modicon PLCsA comprehensive suite of tools
  • ProWORX 32 provides everything you need to start, configure, test and complete your project – quickly, reliably and professionally.
32-bit processing
  • Utilise the power of state-of-the-art operating systems for optimal development and operational performance.
High performance
  • ProWORX 32 has been designed for the power of today’s modern PCs to deliver new capabilities and unrivalled usability. With more speed and greater memory, ProWORX 32 has been re-engineered into a high performance, high productivity tool.
Auto programme conversion
  • Convert older Modsoft and Concept programmes automatically.
Project emulator
  • The project emulator provides the ability to test projects prior to running them in the PLC run-time environment to ensure your system will run at peak efficiency.
The future of 984 Ladder LogicProWORX 32 is the flexible, easy-to-use cross-platform programming software for Modicon range PLCs. It gives you the power to programme all your Modicon controllers online or offline, manage your I/O subsystems, and analyse your plant’s activity in real-time, all in a familiar Windows environment.
支持操作系统:Windows XP,7
安装前必看https://doc.eleok.com/1328.html
安装文件下载地址:内含PROWORX32 V2.1主安装程序和Proworx32 V2.1 SP2升级补丁安装程序,先安装主程序,后安装补丁。
本文仅提供安装程序,不提供授权,在没有授权情况下可以编辑查看25个网络内的程序,如果授权后则无此限制。仅供个人在家学习用途。
GMT+8, 2025-4-26 11:28
