【涨姿势】教学用机械电子行业专用英语,中英文对照,值得收藏!
bloodfate 发表于 2015-11-30 16:06:46 | 显示全部楼层 |阅读模式
机械电子行业中英对照提供参考,转载自工控帮教育科技有限公司!
焊锡品质类
1 冷焊 cold solder
2 零件偏移 component shifted
3 污损 contamination
4 坏件 damaged component
5 锡多 excessive solder
6 装插不良 improper insertion
7 绝缘不良 insulation damaged
8 线脚长 lead protrusion out of spec
9 漏点胶 missing glue
10 漏标示 missing marking
11 近似短路 near short
12 无线尾 no lead protruded
13 翘皮 peeling off
14 极性反 polarity reversed
15 成型不良 poor preforming
16 锡桥 solder bridge
17 锡裂 solder crack
18 锡尖 solder icicle
19 锡少 solder insufficient
20 防焊漆胶落 solder mask peeling off
21 锡渣 solder spatter
22 锡洞 solder void
23 错件 wrong part
ICT Fail Cause and Repair Actions
1 短路 Short
2 零件插反 Backward Part
3 板丢失 Board Lost
4 板修复 Board Repaired
5 板报废 Board Scrapped
6 板送去分析 Board Sent For Analysis
7 零件损坏 Broken Part
8 零件缺陷 Defective Part
9 掉件 Missing part
10 加零件 Part Added
11 零件修复 Part Repaired
12 换零件 Part Replaced
13 PCB缺陷 PCB Defect
14 PCB开路 PCB Open
15 加锡 Solder Added
16 桥焊 Solder Bridge
17 去锡 Solder Removed
Solding quality
1 空焊 Empty Solder
2 包焊 Excess Solder
3 浮焊 Floating Solder
4 冰柱 Icing
5 虚焊 Inveracious Soldering
6 掉件,漏件 Missing Component
7 开路 Open
8 漏焊 Open Solder
9 锡桥 Solder Bridge
10 锡尖突出 Solder Tip
11 锡裂 Split Solder
Operational defect terms
1 零件插反 Backward Part
2 零件损坏 Broken Part
3 碰伤 Bumps
4 异物 Foreign Part
5 零件错位 Misaligned Part
6 漏件 Missing Parts (component)
7 粘胶 Paint Adhesion
8 刮伤 Scratches
9 错件 Wrong Part
Others
1 不正常 Abnormal
2 附件 Accessory
3 外观 Apperance
4 装配 Assembling
5 附着,贴附 Attached
6 弯曲 Bent
7 束线 Bind
8 翘皮 Blister/peeling
9 接 Bridge
10 破损 Broken
11 毛边 Burrs
12 裂纹 Chip / crack
13 夹住 Clip
14 污染 Contamination
15 腐蚀 Corrosion
16 交叉 Cross
17 损坏 Damage
18 减少 Decrease
19 深刮伤 Deep Scratch
20 缺点 Defect
21 变形 Deformed
22 凹痕 Dent
23 偏差 Deviation
24 尺寸 Dimension
25 变色(白化) Discoloration
26 化状箱 Display box
27 双重 Double
28 脱落 Drop , Tall off
29 超过 Excess
30 假焊 False Solder (Cold)
31 频率 Fequency
32 塞住 Fill Up
33 浮 Float
34 异物 Foreign Material
35 碎片塞 Fragement
36 胶 Glue
37 溢胶 Glue overflow
38 重 Heavy
39 不清楚 illegible
40 不完全 Incomplete
41 增加 Increase
42 确认 Indentify
43 指示灯 Indicate Lamp
44 不合治具 Ingagued
45 未固定 Insecurely
46 插配 Insertion
47 内部 Inside
48 干扰 Interference
49 间断,不安定 Intermittent
50 杂物 Junk
51 纠缠 Kink
52 布置,配置 Layout
53 线脚 Lead
54 浅音 Leakage Sound
55 翘起 Lifted
56 轻 Light
57 位置 Location
58 松 Loose
59 方向不对 Misorientation
60 未镀表层 Misplating
61 欠缺 Missing
62 混 Mix
63 多重 Multiple
64 不良 No Good (NG)
65 偏心 Off center
66 振荡 Oscillation
67 外部 Outside
68 脱漆 Paint drop
69 部分 Partial
70 铜箔 Pattem (PAD)
71 太差 Poor
72 凸 Protrude
73 残留物 Residue
74 粗糙 Roughness
75 生锈 Rust
76 LED 数字分节 Segment
77 陷 Sink
78 滑动 Slide
79 脱落 Slip
80 锡珠 Solder Ball
81 流锡 Solder Flow
82 分开,分隔 Sparation
83 污点 Stain
84 粘 Stick
85 薄 Thickness
86 紧 Tight
87 透明 Transparent
88 不平 Uneven
89 不顺 Unsmooth
90 上下颠倒 Upside down
91 漆 Varnish Paint
92 缺洞 Void (Holes)
93 弱 Weak
再提供一些
AAcceleration 速化反应(台)加速反应
Accelerator 加速剂,速化剂(台)促进剂,催化剂
Acceptable Quality Level (AQL)允收品质水准(台)合格质量水平
Access hole 露出孔,穿露孔(台)余隙孔
Accuracy 准确度(台)精确度
Acid Dip 浸酸(台)弱酸蚀
Acrylic(resin) 压克力(台)丙烯酸(树脂)
Active Parts 主动零件(台)有源器件
Anisotropic Conductive Film(Adhesive) 单向导接着膜(台)单向导电膜
Anneal 韧化(台)退火
Any Layer Interstitial Via Hole(ALIVH)阿力制程(台)全层内部导通孔(工艺),任意层内部通孔(工艺)
Area Array Package 面积格列封装(台)面数组封装
BBall Grid Array 球脚数组(台)球栅数组
Bandability 可弯曲性(台)可挠性
Bandwidth 频带宽度,频宽(台)带宽
Banking Agent 护岸剂 (台)护堤剂
Bare Board 空板,未装板(台)裸板
Bare Chip Assembly 裸体芯片组装(台)裸芯片安装
Basic Grid 基本方格(台)基本网络
Blanking 行空断开(台)落料
Bleeding 渗流(台)渗出
Block Diagram 电路系统整合图(台)方块框图
Blotting 干印(台)吸墨
Blow Hole 吹孔(台)气孔
Bond Strength 结合强度 ,固着强度(台)粘合强度
Bondability 结合性,固着性(台)粘合性
Bonding Sheet (Ply ,Layer) 接合片,接着层(台)粘结片
Bonding Wire 结合线(台)键合线
Brazing 硬焊(台)钎焊
Breakaway Panel 可断开板(台)可断拼板
Breakdown Voltage 崩溃电压(台)击穿电压
Bright Dip 光泽浸渍处理 (台) 浸亮
Build - up 增厚,堆积,增层 (台) 积层
Build - up Multiayer (BUM)增层法多层板(台)积层法多层板
Burr 毛头(台)毛剌
Bus Bar 汇电杆(台)总线
CCap Laminaton 帽式压合法(台)覆盖层压法
Cavity Down / Cavity Up 方凹区朝下/方凹区朝上(台)空腔区朝下/空腔区朝上
Cell Phone 行动电话(台)移动电话
Chase 网框(台)网框
Chemical Resistance 抗化性,耐化性(台)耐化学性
Chip 芯片,晶粒,片状 (台) 芯片
Chip on Board (COB) 晶板接装法(台)载芯片板
Chip Scale Package 芯片级封装 (台) 芯片级安装
Circumferential Separation 环状断孔 (台) 环开断裂
Clad / Cladding 披覆 (台) 覆箔
Clinched Lead Terminal 紧箱式引脚 (台) 折弯引脚
Clok Frequency 时脉速率 (台) 时钟频率
Coaxial Cable 同轴缆线 (台) 同轴电缆
Cold Solder Joint 冷焊点 (台)虚焊点
Comparative Tracking Index 比较性漏电指数(台)相比起痕指数
Complex Ion 错离子 (台) 络离子
Component Hole 零件孔 (台) 组件孔
Component Side 组件面 (台) 组件面
Condensation Soldering 凝热焊接,液化放热焊接 (台) 冷凝焊接
Conductive Anodic Filament 玻纤纱式漏电 (台)阳极性玻纤丝的漏电
Conductor Spacing 导体间距(台)导线间距
Core (Board) 核心板,核板 (台)芯板
Core Material 内层板材,核材 (台)内层芯材
Corner Crack 通孔断角(台)拐角裂缝
Corner Mark 板角标记(台)拐角标记
Counterboring 垂直向下扩孔,埋头孔 (台) 沈头孔
Countersinking 锥型扩孔,喇叭孔 (台) 锥形孔
Coupling Agent 耦合剂 (台) 偶联剂
Coupon , Test Coupon 板边试样(台)附连测试板
Coverlayer ,Coverlay 表护层(台)覆盖层
Crease 皱折(台)折痕
Creep 潜变(台)蠕变
Crosshatching 十字交叉区(台)开窗口
Crossover 越交,搭交 (台)跨交
Crosstalk 噪声,串讯 (台)串扰
Cure 硬化,熟化 (台)固化,硫化
Current、Carrying Capability 载流能力(台)载流量
Curtain Coating 濂涂法 (台)帘幕法
DDaisy Chaining 菊花瓣连垫 (台)串推
Deburring 去毛头 (台)去毛剌
Definition 边缘逼真度 (台)清晰度
Denier 丹尼尔 (台)坦尼尔
Dent 凹陷 (台) 凹坑
Deposition 沉积, 附积(台)沉积
Desmearing 除胶渣 (台)去钻污
Dewetting 缩锡 (台) 半润湿
Diazo Film 偶氮棕片 (台)重氮底片
Dicing 芯片分割 (台)切片
Die Attach 晶粒安装 (台)管芯安装
Die Bonding 晶料接着 (台) 管芯键合
Dielectric Breakdown 介质崩溃 (台)介质击穿
Dielectrie Breakdown Voltage 介质崩溃电压(台)介质击穿电压
Dielectric Constant ,Dk or εr 介质常数 (台)介电常数
Differential Scanning Calorimetry (DSC) 微差扫瞄热卡分析法 (台)示扫描量热法
Dimensional Stability 尺度安定性 (台)尺寸稳定性
Direct / Indirect Stencil 直间版膜 (台)直接/间接法网版
Discrete Component 散装零件(台)离散组件
Disspation Factor (Df) 散失因素(台)损耗因素
Drill Facet 钻尖切削面(台)钻尖切削面
Dual Wave Soldering 双波焊接 (台) 双波峰焊
Dynamic Flex (FPC)动态软板(台)动态挠性板
Dynamic Mechanical Analysis (DMA)动态热机分析法(台)动态力学分析法,热机械分析法
EEddy Current 涡电流(台)涡流
Edge -Board Connector 板边 (金手指)承接器(台)板边连接器
Edge -Board Contact 板边金手指(台)板边插头
Edge Spacing 板边空地,边宽 (台)边距
EDTA 乙 = 胺四醋酸 (台) 乙 = 胺四乙酸
Electric Strength (耐)电性强度 (台)电气强度
Electro - deposited Photoresist 电着光阻,电泳光阻(台)电沉积光致抗蚀剂
Electroless Deposition 无电镀,化学镀 (台)无电电镀,化学镀,非电解电镀
Electro - phoresis 电泳动,电渗,电子构装 (台) 电泳
Etchback 回蚀 (台) 凹蚀阴影
Etch Factor 蚀刻因子,蚀刻函数 (台) 蚀刻系数
Etching Indicator 蚀刻指针 (台) 蚀刻指示图
Etching Resist 抗蚀阻剂 (台) 抗蚀刻
Eutetic Composition 共融组成 (台)共晶组成
Excimer Lesar 准分子雷射 (台) 准分子激光
FFace Bonding 晶面朝下之结合(台)倒芯片键合
Fatingue Strength 抗疲劳强度(台)疲劳强度
Fibet Exposure 玻织显露 (台) 露纤维
Fiducial Mark  基准记号,光学靶标 (台)基准标记
Film Adhesive 接着膜,粘合膜 (台)粘结膜
Fine pitch 密脚距,密线距,密垫距(台)精细节距
GGate Array 闸机数组,闸列(台)门阵列
Gel Time 胶性时间 (台)胶化时间,凝胶时间
Gelation Particle 胶凝点 (台)凝胶点
Ghost Image 阴影 (台)重影
Glass Transition Temperature , Tg 玻璃态转化温度(台)玻璃化温度,玻璃态转变温度
Grid 标准格(台)网格
Grid Wing Lead(台)契形引线(脚)
HHalation 环晕(台)晕环
Hay Wire 跳线 (台)附加线
Holding Time 停置时间 (台) 停留时间
Hole Breakout 孔位破出 (台) 破坏
Hole Density 孔数密度 (台) 孔密度
Hole Pull Strength 孔壁抗拉强度(台)孔拉脱强度
Hole Void 破洞 (台) 孔壁空洞
Hole Air Soldrt Levelling (HASL) 喷锡 (台)热风整平
Hull Cell 哈尔槽(台)霍尔槽
IIcicle 锡尖 (台)焊料毛剌
Imaging 成像处理 (台)成像
Imperegnate 含浸 (台)浸渍
Information Appliance (IA)信息家电(台)信息家电
Integrated Circuit (IC) 集成电路器(台)集成电路
Interface 接口 (台)接口
JJ - Leand J 型接脚 , 弯钩型脚(台) J形引线
Jump Wire 跳线 (台) 跨接线
K
Kapton 聚亚酰胺软材 (台) 聚酰亚胺薄膜
Kiss Pressure 吻压,低压 (台) 接能压力
Known Good Die (KGD) 已知之良好芯片 (台) 已知好芯片
LLaminar Flow 平流 (台) 层流
Laminate (S)基板、积层板(台)层压板
Land 孔环焊垫,表面(方型) 焊垫 (台)连接盘,焊盘
Land Grid Array (LGA) 承垫 (台) 连接盘,焊盘
Landless Hole 无环通孔 (台) 无连接盘导通孔,无焊盘导通孔
Laser Ablation 雷射烧蚀,雷射成孔 (台) 激光成孔
Lead Pitch 脚距,中距,跨距 (台) 引脚节距
Leakage Current 漏电电流 (台) 漏电流
Legend 文字标记 ,符号 (台) 字符
Lifted Land 孔环 (或焊垫)浮起 (台)连接盘起翘
Ligand 错离子附属体 (台) 内层配位体
Liquid Photoimagible Solder Mask ,LPSM 液态感光防焊绿漆 (台)液体光致辞阻焊剂
Loss Tangent (Tan δ ,DK ) 损失正切 (台)介质损耗角压切,介质损耗因子
MMaster Drawing 主图 (台) 布设总图
Mat 垫 (台) 毡
Mealing 泡点 (台) 粉点
Measling 白点 (台) 白斑
Meniscograph Test 弧面状沾锡试验 (台) 变面试验
Metal Core Boad  金属夹心板 (台) 金属芯(印制)板
Minimum Annular Ring 孔环下限 (台) 最小环宽
Minimum Electrical Spacing 下限电性间距,最窄电性间距 (台)最小电气间距
Mixed Component Mounting Technology 混合零件之组装技术 (台)混安装技术
Modem 调变及解调器,资料机 (台) 调制 - 调解器
Module 模块 (台) 模件、组件、模块
Moisture and  Insulation Resistance Test 湿气与绝缘电阻试验(MIR) (台) 潮热绝缘电阻试验
Monting Hole 组装孔, 机装孔 (台) 安装孔
NNumerically Controlled ( N.C.)数值控制 (台) 数控
Negative 复片, 钻尖第一面外缘变窄 (台) 负像
Negative - acting Resist 负性作用之阻剂,负型阻剂 (台)负性抗蚀剂
Negative Etchback 反回蚀 (台) 负凹蚀
N - Methyl Pyrrolidone  (NMP) N - 甲基四氢吡咯 (台) N - 甲基吡咯烷酮
Nodule 瘤 (台) 结瘤
Noise Budget 噪声上限 (台) 最大杂音,最大噪声
Nominal Cured Thickness 标示厚度 (台) 标称厚度
Non - Wetting 不沾锡 (台)不润湿
Nylon 耐龙 (台) 尼龙
OOff - Contact 架空 (台) 非接触 (印刷)
Offset 第一面大小不均 (台) 钻面不匀
Outer Lead Bond (OLB) 外引脚结合 (台) 外部引线粘接
Oligomer 寡聚物 (台) 低聚物
Outgassing 出气,吹气 (台) 逸气
Outgrowth 悬出,横出,侧出 (台) 镀层情况
Overhang 总浮空 (台) 镀层突出
Overpotential 过电位,过电压 (台) 趋电势
PPanel Plating 全板镀铜 (台) 整板电镀
Passive Device (Component) 被动组件 (零件) (台)无源组件
Pattern Plating 线路电镀 (台) 图形电镀
Patten Process 线路电镀法 (台) 图形电镀法
Peel Strength 抗撕强度 (台) 剥离强度
Permittivity 容电率 (台) 电容率 ,介电常数
Phototinitator 感光启始剂 (台) 光敏剂
Pin 接脚,插梢,插针 (台) 管脚
Pin Grid Array (PGA) 针脚格列封装体 (台) 针栅数组
Pitch 跨距,脚距,垫距,线距,中距 (台) 节距
Pits 凹点 (台) 麻点
Plasma 电浆 (台) 等离子
Plastic - BGA (PBGA) 塑料质球脚封装体 (台) 塑料球栅数组
Platen 热盘 (台) 加热板
Plug 插脚,塞柱 (台) 插头 , 插销
Polarizing Slot 偏槽 (台) 偏置定位槽
Porosity Test 疏孔度试验 (台) 孔隙率试验
Positive Acting Resist 正型光阻剂 (台) 正性抗蚀剂
Prepreg 胶片 , 树脂片 (台) 粘结片 , 半固化片
Process Camera 制程用照相机 (台) 制版照相机
Purge ,Purging 净空 , 净洗 (台)  洗净
Quad Flat Pack (QFP) 方扁形封装体 (台) 扁平方型封装
Quality Conformance Test Ciruitry (Coupon )品质符合之试验线路(样板) (台) 质量一致检验电路
RReflow Soldering 重熔焊接 , 熔焊 台)再流焊
Register Mark 对准作标记(台)对准标记
Registration 对准度 (台) 重合度
Reinforcement 补强材 (台) 增强材料
Relamination (Re - Lem) 多层板压合 (台) 多层板压制
Relative Permitivity (εr)相对容电率 (台) 相比介电常数
Resin Coated Copper Foil 背胶铜箔 (台) 涂树脂铜箔,附树脂铜箔
Resin Flow 胶流量 , 树脂流量 (台) 树脂流动度
Resin Recession 树脂缩陷 (台) 树脂凹缩
Resin Rich Area 树脂丰富区 , 多胶区 (台) 树脂钻污
Resin Starved Area 树脂缺乏区 ,缺胶区 (台) 缺胶区
Resist 阻剂 ,阻膜 (台) 抗蚀剂
Resolution 解像 ,解像变,分辨率 (台) 分辨率
Reverse Image 负片影像 (阻剂) (台) 负图像
Rigid - Flex Printed Board 硬软合板 (台) 刚挠印制板
Ring 套环 (台) 钻套
Ripple 纹波 (台) 波动 ,脉动
Roller Coating 滚筒涂布法 、辊轮涂布法 (台) 辊涂式
SScratch 刮痕 (台) 划痕
Secondary Side 第二面 (台) 辅面
Self-Alignment 自我回正 (台) 自定位
Shadowing 阴影 ,回蚀死角 (台) 凹蚀阴影
Shear Strength 抗剪 (力) 强度(台)剪切强度
Silver Fhrough Hole (STH)银胶通孔 ,银胶贯孔 (台) 银浆通孔,银浆贯孔
Single-Inline Package (SIP) 单边插脚封装体 (台)单列直插式封装
Solder Connection 焊接点 (台) 焊点
Solder Paste 锡膏 (台) 焊膏
Solder Plug 锡塞 ,锡柱 (台) 焊料堵塞
Solder Spread Teat 散锡试验 (台) 焊料扩展试验
Solder Webbing 锡网 (台) 网状残锡
Soldering 软焊 ,焊接 (台) 软钎焊 ,焊接
Solid Content 固体含量 ,固形份 ,固形物
Solubility Product 溶解度乘积 ,溶解度积(台)容度积
Splay 斜钻孔 (台) 斜孔
Spray Coating 喷着涂装 ,喷射涂装 (台) 喷涂
Stencil 片膜 (台) 漏板 ,模版
Stringing 拖尾 ,牵丝 (台) 带状线
Stripper 剥除液 ,剥除器 (台) 剥离液
Supported Hole (金属) 支助通孔 (台) 支撑孔
Surface Mounting Technology 表面贴装技术 (台) 表面安装技术
Surge 突流 、突压 (台) 波动
Swaged Lead 压扁式引脚 (台) 挤压引线
Syringe 挤浆法 ,挤膏法,注浆法 (台) 注射法
TTab 接点 ,金手指 (台) 印制插头
Telegraphing 浮印 ,隐印 (台) 露印
Template 模板 (台) 靠模板
Tensile Strength 抗拉强度 (台) 拉伸强度 ,抗拉强度
Terminal 端子 (台) 端接 (点)
Thermal Conductivity 导热率 (台) 热导率
Thermal Shock Test 热震荡试验(台)热冲击试验
Thermogravimetric Analysis (TGA) 热重分析法 (台)热解重量分析法
Thermosonic Bonding 热超音波结合 (台) 热声连 (焊)接
Thermount 聚醯胺短织席材 (台) 聚酰胺纤维无纺布
Thin Small Outline Packange (TSOP) 薄小型集成电路器 (台)薄小外形封装
Thixotropy 抗垂流性 ,摇变性 ,摇溶性 ,静凝性 (台) 触变性
Tin Indicated 浸镀锡 (台) 浸锡
Total Indicated Runout (TIR) 总体标示偏转值 (台)指针总读数
Touch Up 触修 ,简修 ,小修, (台) 修版
Transfer Bump 移用式突块 ,转移式突块 (台) 变换凸块
Treament ,Trearing 含浸处理 (台) 浸渍
Twist 板翘 、板扭 (台) 扭曲
UUtimate Tensile Strength (UTS)极限抗拉强度 (台)极限拉伸强度
Ultra Violet Curing (UV Curing) 紫外线硬化 (台)紫外线固化
Ultrasonic Bonding 超音波结合 (台) 超声连接
Unbalaned Transmission Line 非平衡式传输线 (台)非均衡传输线
Unsupported Hole 非镀通孔 (台) 非支撑孔
Urethane 胺基甲酸乙脂 (台) 氨基甲酸乙酯
VV-Cut V型切槽 (台) V槽切割
Vacuum Evaporation (or Deposition )真空蒸镀法 (台)真空镀膜法
Vacuum Lamination 真空压合 (台) 真空压制
Varnish 清漆 ,凡力水 (台) 树脂漆
Visual Examination (Inspection) 目视检查 (台) 目检
Voltage Breakdown (崩)溃电压 (台) 击穿电压
Voltage Plane Clearance 电压层的空环 (台) 电源层隔离
WWaviness 波纹 、波度 (台) 云织
Weave Exposure 织纹显露 ;Weave Texture 织纹隐现 (台)露布纹
Wedge Void 楔形缺口 (破洞) (台) 楔形空洞
Wet Lamination 湿压膜法 (台)湿法贴膜
Wetting 沾湿 、沾锡 (台) 焊料润湿
Wicking 灯芯效应 (台) 芯吸
Wire Bonding 打线结合 (台) 金属丝连接
Working Master 工作母片 (台) 工作原版
Wrinkle 皱褶 ,皱纹 (台) 皱褶
ZZigzag Inline Package (ZIP) 链齿状双排脚封装件 (台)弯曲式直插封装
GMT+8, 2025-4-21 04:04
